1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Device Driver question
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Tue, 31 Oct 2006 10:51:10 -0600
Hi David,
David Dudley wrote:
From the talk on Device Support is says that the DSET - initialize routine, when passed a parameter of 1, "Can be used as a final startup step. All device address information is now known."
Does this imply that once the iocinit() routine has called the
initialize routine with the parameter of 1, I can infer that no
additional I/O items could be defined?
Unless you're providing the ability to change addresses at runtime (by implementing Extended Device Support, see the R3.14.8.2 iocAppDevGuide section 12.5 for details) the answer is yes. The full initialization order for a device support is
1. For all dsets, call dset->init(0)
2. For all records, call rset->init_record(prec, 0) which in turn calls dset->init_record(prec, 0)
3. For all records, if a dsxt was registered call dsxt->add_record(prec)
4. For all records, call rset->init_record(prec, 1) which in turn calls dset->init_record(prec, 1)
5. For all dsets, call dset->init(1)
If you don't register a dsxt during your dset->init(0) call then it is not possible to change the record's INP/OUT field at runtime so your inference would be correct.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
EPICS Device Driver question David Dudley
Prev: EPICS Device Driver question David Dudley
Next: Re: EPICS Device Driver question David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
