I am not sure if xprop works on solaris.
But xprop is part of X, and will only work if the medm window is ALREADY
open. That is if you enter the medm command and the xprop right after,
the xprop will not work because the adl file is not yet open.
So you may need to use the sleep command.
An alternative is to soft link the adl file and open that new file.
Those are the only 2 solutions I have found. In that latter case, you
cannot get rid of the adl extension.
Annoying huh?
Emmanuel
On Mon, 2006-10-16 at 18:50 +0100, Simon Rees wrote:
> c) looked at a previous solution described in tech talk here:
> http://www.aps.anl.gov/epics/tech-talk/2006/msg00884.php
> Unfortunately the solution described in (c) only seems to
> be supported under linux (xprop -set doesn't work on our Solaris
> platform).
- Setting MEDM window title Simon Rees
WARNING NOTIFICATION From Argonne Credit Union REF-ID #86153 Argonne Credit Union
<2006>
<2006>
