1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: sequencer installation
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Mon, 09 Oct 2006 11:08:49 -0500
If a configure/RULES_BUILD file exists in a support module defined
in an application's RELEASE file it will be included by Makefiles
during the build. This allows a support module to create module
specific build rules to be used by ioc applications which use the
support module.
When a make is done in the configure directory of a makeBaseApp.pl
application a RULES_INCLUDE file is created in each O.<arch>
subdirectory. This file contains an include line for a RULES_BUILD
file from each support module defined in the configure/RELEASE file
(except EPICS_BASE). The created RULES_INCLUDE file will be included
by EPICS_BASE configure files during the build.
Janet
Eric Norum wrote:
I'm sure that Janet can provide a better explanation of this, but the sequencer seems to work fine for me without requiring any manual additions to the RULES_BUILD file. I have only to add a definition for SNCSEQ in the configure/RELEASE file:
SNCSEQ=/usr/local/iocapps/R3.14.8.2/modules/soft/seq/2-0-11-asd2
On Oct 6, 2006, at 8:00 PM, Emmanuel Mayssat wrote:
Mark,
I also need to include the RULES_BUILD file that comes with the
sequencer source to be able to build the C files from the st one.
MyIoc_SRCS=sequencer.st
include ${EPICS_SEQUENCER_TOP_DIR}/configure/RULES_BUILD
Emmanuel
-- Eric Norum <[email protected] <mailto:[email protected]>> Advanced Photon Source Argonne National Laboratory (630) 252-4793
RE: sequencer installation Mark Rivers
RE: sequencer installation Emmanuel Mayssat
Re: sequencer installation Eric Norum
Prev: Re: sequencer installation Eric Norum
Next: RE: Failed to install sequencer 2.0.11 on WIN32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: CA disconnect mechanism Jeff Hill
