1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Failed to install sequencer 2.0.11 on WIN32
To: <[email protected]>
Date: Fri, 6 Oct 2006 18:33:47 -0500
	I am new to EPCIS and hope to get some help to solve
installation problem.
	I am working on winXP Pro with CGWIN (GNUmake 3.81), and Visual
C++ 2005 express as the compiler.  I run 'make' in the VC2005 CMD window
because I could not figure out how to do it right in CGWIN.  I did get
the EPICS base-3.14.8.2 installed without modifying the file
configure/RULES_BUILD.  NO warning or error messages have been found and
the exmaple got compiled and run ok.
	However, when I tried to install the sequencer package 2-0-11, I
run into trouble and here is the complete messages (between ***):
C:\CGWIN\usr\local\synApps_5_1_1\support\seq\2-0-11>make
make -C configure install
make[1]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/configure'
perl /base-3.14.8.2/configure/tools/convertRelease.pl -h win32-x86
checkRelease
perl /base-3.14.8.2/configure/tools/makeMakefile.pl O.win32-x86 ../..
perl /base-3.14.8.2/configure/tools/mkdir.pl O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/configure/O.win32-x86'
CONFIG_APP_INCLUDE
RULES_INCLUDE
make[2]: Leaving directory
make[1]: Leaving directory
make -C src install
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src'
make -C pv install
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv'
perl /base-3.14.8.2/configure/tools/makeMakefile.pl O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory
`/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv/O.win32-x86'
make[3]: Leaving directory
Installing generic include file ../../../include/pv.h
mkdir ../../../include
Installing generic include file ../../../include/pvAlarm.h
Installing generic include file ../../../include/pvCa.h
cl /nologo /EHsc /GR -c          -DPVCA    /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0  /Ox /GL
  /W3 /w44355       /MD    -I. -I.. -I..\\..\\..\\include\\os\\WIN32
-I..\\..\\..\\include -I\\base-3.14.8.2\\include\\o
s\\WIN32 -I\\base-3.14.8.2\\include       /Tp ..\\pvNew.cc
pvNew.cc
s\\WIN32 -I\\base-3.14.8.2\\include       /Tp ..\\pv.cc
pv.cc
..\pv.cc(247) : warning C4390: ';' : empty controlled statement found;
is this the intent?
..\pv.cc(343) : warning C4390: ';' : empty controlled statement found;
is this the intent?
..\pv.cc(368) : warning C4390: ';' : empty controlled statement found;
is this the intent?
s\\WIN32 -I\\base-3.14.8.2\\include       /Tp ..\\pvCa.cc
pvCa.cc
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
/release     /implib:pv.lib /out:pv.dll      pvNew.o
bj pv.obj pvCa.obj      /base-3.14.8.2/lib/win32-x86/ca.lib
/base-3.14.8.2/lib/win32-x86/Com.lib
LINK : warning LNK4044: unrecognized option
'/base-3.14.8.2/lib/win32-x86/ca.lib'; ignored
'/base-3.14.8.2/lib/win32-x86/Com.lib'; ignored
   Creating library pv.lib and object pv.exp
pvNew.obj : error LNK2001: unresolved external symbol "public: bool
__thiscall epicsTime::operator<(class epicsTime cons
t &)const " (??MepicsTime@@QBE_NABV0@@Z)
__thiscall epicsTime::operator<=(class epicsTime con
st &)const " (??NepicsTime@@QBE_NABV0@@Z)
pvNew.obj : error LNK2001: unresolved external symbol "public: class
epicsTime __thiscall epicsTime::operator+(double co
nst &)const " (??HepicsTime@@QBE?AV0@ABN@Z)
__thiscall epicsTime::epicsTime(class epicsTime const &)"
 (??0epicsTime@@QAE@ABV0@@Z)
__thiscall epicsTime::epicsTime(struct epicsTimeStamp con
st &)" (??0epicsTime@@QAE@ABUepicsTimeStamp@@@Z)
__thiscall epicsTime::epicsTime(struct time_t_wrapper con
st &)" (??0epicsTime@@QAE@ABUtime_t_wrapper@@@Z)
__thiscall epicsTime::epicsTime(struct local_tm_nano_sec
const &)" (??0epicsTime@@QAE@ABUlocal_tm_nano_sec@@@Z)
__thiscall epicsTime::epicsTime(struct timespec const &)"
 (??0epicsTime@@QAE@ABUtimespec@@@Z)
__thiscall epicsTime::epicsTime(struct l_fp const &)" (??
0epicsTime@@QAE@ABUl_fp@@@Z)
__thiscall epicsTime::epicsTime(class aitTimeStamp const
&)" (??0epicsTime@@QAE@ABVaitTimeStamp@@@Z)
pvNew.obj : error LNK2001: unresolved external symbol "public: virtual
void __thiscall epicsThreadRunable::show(unsigned
 int)const " (?show@epicsThreadRunable@@UBEXI@Z)
__thiscall epicsThreadRunable::~epicsThreadRunabl
e(void)" (??1epicsThreadRunable@@UAE@XZ)
__thiscall epicsEvent::epicsEvent(enum epicsEventInitialS
tate)" (??0epicsEvent@@QAE@W4epicsEventInitialState@@@Z)
pv.obj : error LNK2001: unresolved external symbol _epicsMutexLock@4
pv.obj : error LNK2001: unresolved external symbol _epicsAssert@16
_epicsTimeGetCurrent@4
pv.obj : error LNK2001: unresolved external symbol _epicsMutexUnlock@4
_epicsMutexOsiMustCreate@8
pvCa.obj : error LNK2001: unresolved external symbol
__imp__ca_task_exit@0
__imp__dbr_value_size
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_message@4
__imp__ca_element_count@4
__imp__ca_flush_io@0
__imp__ca_current_context@0
__imp__ca_array_put_callback@24
__imp__ca_search_and_connect@16
__imp__ca_pend_event@8
__imp__ca_attach_context@4
__imp__ca_array_put@16
__imp__ca_add_masked_array_event@52
__imp__dbr_value_offset
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_state@4
__imp__ca_context_create@4
__imp__ca_field_type@4
__imp__ca_clear_event@4
pvCa.obj : error LNK2001: unresolved external symbol __imp__dbr_size
__imp__ca_array_get_callback@20
__imp__ca_array_get@16
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_pend_io@8
pvCa.obj : error LNK2001: unresolved external symbol __imp__ca_puser@4
__imp__ca_clear_channel@4
pv.dll : fatal error LNK1120: 41 unresolved externals
make[3]: *** [pv.dll] Error 96
make[2]: *** [install.win32-x86] Error 2
make[1]: *** [pv.install] Error 2
make: *** [src.install] Error 2
It seems to me the key is these two lines--
But I have no idea what led to this.
Here are my settings for PATH, INCLUDE and LIB in winXP.
Path=C:\Program Files\Microsoft Platform SDK for Windows Server 2003
R2\Bin;C:\Program Files\Microsoft Platform SDK for
Windows Server 2003 R2\Bin\WinNT;C:\Program Files\Microsoft Visual
Studio 8\Common7\IDE;C:\Program Files\Microsoft Visua
l Studio 8\VC\BIN;C:\Program Files\Microsoft Visual Studio
8\Common7\Tools;C:\Program Files\Microsoft Visual Studio 8\SD
K\v2.0\bin;C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727;C:\Program
Files\Microsoft Visual Studio 8\VC\VCPackages;C:\WIN
DOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\program
files\matlab\r2006b\bin;c:\program files\matlab\r2006b\bin\
win32;c:\program
files\ultraedit;c:\cgwin\bin;C:\CGWIN\base-3.14.8.2\bin\win32-x86;
LIB=c:\cgwin\base-3.14.8.2\lib;C:\CGWIN\base-3.14.8.2\lib\win32-x86;C:\P
Server 2003 R2\Lib;C:\Program Files\Microsoft Visual Studio
8\VC\LIB;C:\Program Files\Microsoft Visual Studio 8\SDK\v2.0
\lib;
LIBPATH=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
INCLUDE=C:\CGWIN\base-3.14.8.2\include;C:\CGWIN\base-3.14.8.2\include\os
\WIN32;C:\Program Files\Microsoft Platform SDK f
or Windows Server 2003 R2\Include;C:\Program Files\Microsoft Visual
Studio 8\VC\INCLUDE;
Could you please help on this issue?  Any suggestion is welcome.
Thanks and have a nice weekend!
Zhan
Zhan Zhang
Argonne National Laboratory
X-ray Science Division
Bldg 438, D005
9700 S. Cass Ave
Argonne, IL 60439
Tel: (630) 252-0863
Email: [email protected]
RE: Failed to install sequencer 2.0.11 on WIN32 Mark Rivers
Prev: RE: CA disconnect mechanism Jeff Hill
Next: RE: sequencer installation Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Failed to install sequencer 2.0.11 on WIN32 Mark Rivers
