Emmanuel,
> 1/ Compile the snl program to turn it into a c program
> (In this program there is a epicsExportRegistrar command )
> 2/ Include the c source from 1 into the IOC code by editing the IOC
> Makefile
In general I would recommend NOT doing what you list above. You are
manually converting the SNL program to C, and putting mySNLProgram.c in
the SRCS in Makefile. The problem with that is that then the C code is
in your source directory, and if you change the SNL code then "make"
will not update the C code and the binary.
You should put mySNLprogram.st in the SRCS in Makefile, not
mySNLProgram.c.
RE: sequencer installation Mark Rivers
RE: CA disconnect mechanism Jeff Hill
<2006>
RE: sequencer installation Emmanuel Mayssat
<2006>
