1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: sequencer installation
To: "Emmanuel Mayssat" <[email protected]>, "epics" <[email protected]>
Date: Fri, 6 Oct 2006 16:58:04 -0500
Your *Include.dbd file needs to include a line like the following:
registrar("mySNCprogram")
where  mySNCprogram is the program name of your SNC program.
Is this the problem?
> -----Original Message-----
> From: Emmanuel Mayssat [mailto:[email protected]]
> Sent: Friday, October 06, 2006 1:41 PM
> To: epics
> Subject: sequencer installation
> Here again, I have to deal with the not-s-straight-forward epics build
> system.
> So far I always build against the base. I am referring to the
> configuration and/or config directories at the top my device source.
> In those files the SNC make variable is not set etc.
> The sequencer source build correctly but against a local
> configuration/config directory.
> So far I was able to go from snl to c code and include the c
> code in my
> driver source. But, when I type "help" at the iocsh prompt I
> do not see
> the sequencer commands (such as seqShow, etc).
> 1/ Where are those commands coming from? A library ?
> 2/ I include the seq pv seqDev libraries in my ioc. My sequencer.c
> program is also added as a SRCS to that same ioc. Everything compile
> correctly. But still cannot see the seqShow command in the iocsh help.
> What am I not doing correctly ?
> Emmanuel Mayssat
> Cell: 650/793-0626
> Lyncean Technologies, Inc.
> "See the invisible"
Prev: Re: sequencer installation Emmanuel Mayssat
Next: RE: sequencer installation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
