Here again, I have to deal with the not-s-straight-forward epics build
system.
So far I always build against the base. I am referring to the
configuration and/or config directories at the top my device source.
In those files the SNC make variable is not set etc.
The sequencer source build correctly but against a local
configuration/config directory.
So far I was able to go from snl to c code and include the c code in my
driver source. But, when I type "help" at the iocsh prompt I do not see
the sequencer commands (such as seqShow, etc).
1/ Where are those commands coming from? A library ?
2/ I include the seq pv seqDev libraries in my ioc. My sequencer.c
program is also added as a SRCS to that same ioc. Everything compile
correctly. But still cannot see the seqShow command in the iocsh help.
What am I not doing correctly ?
