1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Epics 3.14.8.2 for Windows still has problems
Cc: Ralph Lange <[email protected]>, EPICS-tech-talk <[email protected]>
Date: Tue, 26 Sep 2006 11:55:54 -0400
I see the same message
C:\testioc>perl c:\epics\base\bin\win32-x86\makeBaseApp.pl -t example
example
Can't find EPICS base
-----Original Message-----
Sent: Tuesday, September 26, 2006 11:28 AM
To: Liyu, Andrei
Cc: Ralph Lange; EPICS-tech-talk
Subject: Re: Epics 3.14.8.2 for Windows still has problems
Liyu, Andrei wrote:
> 2. The example with full path doesn't work.
> C:\testioc>dir
>  Volume in drive C has no label.
>  Volume Serial Number is E886-E139
>  Directory of C:\testioc
> 09/26/2006  10:41 AM    <DIR>          .
> 09/26/2006  10:41 AM    <DIR>          ..
>                0 File(s)              0 bytes
>                2 Dir(s)  22,611,488,768 bytes free
> C:\testioc>c:\epics\base\bin\win32-x86\makeBaseApp.pl -t example
example
> C:\testioc>
What happens if you use this command instead?
     perl \epics\base\bin\win32-x86\makeBaseApp.pl -t example example
I suspect that Windows may be stripping the path information from the
command line when you just type the name of a script, whereas the above
allows perl and hence the script to see the full path to the script.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: Epics 3.14.8.2 for Windows still has problems Andrew Johnson
Prev: Re: Epics 3.14.8.2 for Windows still has problems Andrew Johnson
Next: Re: Epics 3.14.8.2 for Windows still has problems Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
