1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics 3.14.8.2 for Windows still has problems
To: "Liyu, Andrei" <[email protected]>
Cc: Ralph Lange <[email protected]>, EPICS-tech-talk <[email protected]>
Date: Tue, 26 Sep 2006 10:27:56 -0500
Liyu, Andrei wrote:
2. The example with full path doesn't work. ================ C:\testioc>dir Volume in drive C has no label. Volume Serial Number is E886-E139
Directory of C:\testioc
09/26/2006  10:41 AM    <DIR>          .
09/26/2006  10:41 AM    <DIR>          ..
               0 File(s)              0 bytes
               2 Dir(s)  22,611,488,768 bytes free
C:\testioc>c:\epics\base\bin\win32-x86\makeBaseApp.pl -t example example
Can't find EPICS base
C:\testioc>
What happens if you use this command instead? perl \epics\base\bin\win32-x86\makeBaseApp.pl -t example example
I suspect that Windows may be stripping the path information from the command line when you just type the name of a script, whereas the above allows perl and hence the script to see the full path to the script.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
Prev: RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
Next: RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
