1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Experience with CAJ
To: "'Kay-Uwe Kasemir'" <[email protected]>, "'tech talk'" <[email protected]>
Date: Mon, 25 Sep 2006 16:17:28 -0600
The CAJ <=> CA server incompatibility is being tracked as mantis bug
tracking entry 268 (against IOC core's CA server - in EPICS base).
Jeff
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Monday, September 25, 2006 12:15 PM
> To: tech talk
> Subject: Re: Experience with CAJ
> On Sep 25, 2006, at 13:43 , Christopher Larrieu wrote:
> > Does anyone have experience using Cosylab's java channel access
> > (CAJ) in a
> > real-world, production system?  I'm curious about using it in lieu
> > of JCA.
> Hi Chris:
> Are you the same Chris who used to be on the 'other' coast of the US?
> At the SNS, we had problems with the pure java CA client lib when
> it comes to IOCs that use CA security.
> The CA server on the IOCs would enter a state where it's hung.
> New CA connections would create new client threads, but each new
> thread hangs waiting for some semaphore inside the access security
> library's asAddClient() routine.
> Try searching previous tech talk messages:
> http://www.aps.anl.gov/epics/tech-talk/2006/msg00503.php,
> and look around April 25, 2006 for messages from Jeff and me.
> The symptom: No new CA connections, and a 'caget some_PV' will issue
> the 'timeout' error messag after about 1 second
> (as common for missing PVs), but hang for another 29 seconds before
> exiting
> (symptomatic for this error where the new client thread is created
> but then hangs).
> Since this is very bad for operational IOCs, the only remedy being a
> reboot,
> we quit using CAJ for now.
> The problem is probably caused by CAJ sending user/host information
> in the 'wrong'
> order or at a 'bad' time, but with CA it's of course a bit difficult
> to determine
> what's a 'correct' message or the 'right' time ;-).
> At one time we caught the error with a version of EPICS base that was
> patched
> to allow a 'semShow' on the access security semaphore. I think it showed
> that another CA task held the semaphore, but I can't find the detail any
> longer. Maybe Jeff remembers, I'm pretty sure I emailed him the results.
> I also saw occasional messages on the IOC
>    CAS: request from someIP:port => "bad resource ID"
> which only occurred when using CAJ.
> So while I think CAJ is terrific, I would only use it through a gateway
> until these kinks are worked out.
> With the JNI-based CA client library for Java, there are also issues
> that Tom Pelaia at the SNS and Matej at Cosylab are currently
> investigating:
> As far as I understand, the JNI code includes a list for the incoming
> monitors.
> If the java client code doesn't digest them fast enough, that list
> grows ad infimum,
> instead of engaging the CA flow control.
> We first thought it's a memory leak, since the app keeps growing.
> It's not, just a list that grows, but nonetheless fatal.
> -Kay
Re: Experience with CAJ Kay-Uwe Kasemir
Prev: RE: Epics 3.14.8.2 for Windows still has problems Ernest L. Williams Jr.
Next: Re: Epics 3.14.8.2 for Windows still has problems Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Experience with CAJ Kay-Uwe Kasemir
Next: Re: Experience with CAJ Thomas Pelaia II
