Hi Ernest,
Those problems have been fixed. Here are the last few entries in the CVS log.
RCS file: /net/beams-nfs/export/local/cvs/support/autosave/asApp/src/dbrestore.c,v
Working file: dbrestore.c
head: 1.23
branch:
locks: strict
access list:
symbolic names:
synApps_5_2: 1.23
R4-2-1: 1.23
R4-2: 1.22
R4-1-3: 1.22
R4-1-2: 1.20
synApps_5_1: 1.19
R4-1-1: 1.19
R4-1: 1.19
synApps5-0: 1.8.0.2
synApps_5_0: 1.8
R2-3: 1.8
R2-2: 1.7
R2-1: 1.6
R1-3: 1.2
R3_13_branch: 1.2.0.2
R1-2: 1.1.1.1
R1-1: 1.1.1.1
start: 1.1.1.1
std: 1.1.1
keyword substitution: kv
total revisions: 25; selected revisions: 25
description:
revision 1.23
date: 2006/09/07 18:26:19; author: mooney; state: Exp; lines: +22 -16
Malcolm Walters' patches re errno and myPrintErrno
revision 1.22
date: 2006/03/28 22:53:28; author: mooney; state: Exp; lines: +94 -37
Replaced Debug macros with straight code
revision 1.21
date: 2005/12/11 23:26:36; author: rivers; state: Exp; lines: +33 -34
Changes for WIN32; redefined Debug macro, but I don't like it
So release R4-2, which is on the synApps Web site, has the required fix.
http://www.aps.anl.gov/aod/bcda/synApps/autosave/autosave.html
If you write to Tim he can probably put up the latest release, R4-2-1. I am using autosave with both cygwin-x86 and win32-x86.
From: Williams Jr, Ernest L. [mailto:[email protected]]
Sent: Thu 9/21/2006 8:37 PM
To: tech-talk
Cc: Tim Mooney; Kasemir, Kay; Williams Jr, Ernest L.
Subject: AutoSaveRestore for Windows-based softIOCs
Has anyone managed to get autosave/restore working under Win32?
Autosave restore does work for linux-based softIOCs.
Here is the error I get:
"Installing dbd file ../../../dbd/autosave.dbd"
cl -c /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /nologo
/D__STDC__=0 /Ox /GL /W3 /w44355 /MD -I. -I.. -I..\\..\\..\\include
\\os\\WIN32 -I..\\..\\..\\include -Ic:\\epicsBase\\R3.14.8.2\\include\\os\\WIN32
-Ic:\\epicsBase\\R3.14.8.2\\include ..\\dbrestore.c
dbrestore.c
c:\epicsioc\autosave\autosaveapp\src\save_restore.h(12) : error C2010: '.' : une
xpected in macro formal parameter list
..\dbrestore.c(79) : warning C4273: 'pdbbase' : inconsistent dll linkage
c:\epicsbase\r3.14.8.2\include\dbAccessDefs.h(34) : see previous definit
ion of 'pdbbase'
..\dbrestore.c(106) : warning C4244: '=' : conversion from 'double' to 'float',
possible loss of data
..\dbrestore.c(518) : error C2059: syntax error : ')'
..\dbrestore.c(543) : error C2059: syntax error : ')'
..\dbrestore.c(552) : error C2059: syntax error : ')'
..\dbrestore.c(555) : error C2059: syntax error : ')'
..\dbrestore.c(558) : error C2059: syntax error : ')'
..\dbrestore.c(747) : warning C4018: '<' : signed/unsigned mismatch
make[3]: *** [dbrestore.obj] Error 2
make[3]: Leaving directory `C:/epicsIOC/autosave/autosaveApp/src/O.win32-x86'
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory `C:/epicsIOC/autosave/autosaveApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `C:/epicsIOC/autosave/autosaveApp'
make: *** [autosaveApp.install] Error 2
C:\epicsIOC\autosave>
The above error refers to lines containing the string Debug (e.g.):
Debug(10, "ARRAY_BEGIN wasn't found; going to next line of input file\n");
This appears to conflict with MS C++ and its Debug object, hmm?
Ernest L. Williams
- RE: AutoSaveRestore for Windows-based softIOCs Ernest L. Williams Jr.
- AutoSaveRestore for Windows-based softIOCs Williams Jr, Ernest L.
<2006>
<2006>
