1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Alarm trigger for persistent values?
To: "Bernhard Lopez" <[email protected]>, <[email protected]>
Date: Thu, 21 Sep 2006 13:21:28 +0100
Something along the line of:
record (ai, "TEMPERATURE")
	field (SCAN, "1 second")
	field (INP, "CALCULATION PP MS")
record (calc "CALCULATION")
	field (CALC, "(B>C||B<D)?(A+1):0")
      field (INPA, "CALCULATION.VAL")
      field (INPB, "RAWTEMP")
	field (INPC, "RAWTEMP.HIHI")
	field (INPD, "RAWTEMP.LOLO")
	field (HIHI, "60")
      field (HHSV, "MAJOR")
> -----Original Message-----
> From: Bernhard Lopez [mailto:[email protected]]
> Sent: 21 September 2006 08:22
> To: [email protected]
> Subject: Alarm trigger for persistent values?
> Hi,
> At our infrastructure monitoring system we have the case that
> some temperature values should trigger an alarm only if they
> remain above/below a threshold (HIHI/LOLO) for longer than a
> defined amount of time.
> As we could not find support for this feature in the documentation,
> we would be glad to receive a suggestion regarding a solution or
> implementation we could go for.
> The involved sensor devices are represented by "ai" records
> with a home-made device implementation. We use EPICS release
> 3.14 on Linux.
> Many thanks in advance!
> Bernhard.
Alarm trigger for persistent values? Bernhard Lopez
Prev: Alarm trigger for persistent values? Bernhard Lopez
Next: Re: Alarm trigger for persistent values? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
