Hi all,In case you're referring to the ActiveX CA server & client stuff that one can still get from http://ics-web1.sns.ornl.gov/~kasemir/axca/ index.html : Bad idea. It was primarily developed to allow Labview to serve data via Channel Access, but for LabView there are now better solutions, so this has not been maintained for years. Besides, if you wanted to use _that_ to connect your ActiveX stuff to EPICS, it would mean: You write a gateway program in for example Visual Basic that uses the Active X controls that you got for your devices and passes data back and forth between them and the Active X CA server or client. Yes, that would be a much more direct way to get from an IOC databaseWould making a soft IOC and linking the vendor supplied Active X/dll's in to sub() records be a better way to go ? to your devices. And I agree with Mark that writing 'proper' device support is probably better than routines for sub-records, unless this is only a 'one-of' thing that you need to handle. -Kay
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
