1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: cron-type scheduling in database or sequencer?
To: Kay-Uwe Kasemir <[email protected]>
Cc: tech talk <[email protected]>
Date: Thu, 14 Sep 2006 09:01:06 -1000
Kay-Uwe Kasemir wrote:
Hi:
Both the database and the sequencer have good support for
periodic scheduling (scan field resp. delay() routine).
But I now have a need for scheduling things at certain times,
for example "at 00:15 and then every 6 hours",
meaning: run at 00:15, 06:15, 12:15 and 18:15 each day.
spawn a task?
We have the following running every UT midnight
(originally written by Nick Rees):
taskSpawn ("dhsDailyUpdate", 100, 8, 20000, dhsDailyUpdate)
(this is from the IOS's startup script)
and it does:
/* dhsDailyUpdate - task that executes once a day at 00:00 UT to update the file number */
void dhsDailyUpdate()
    time_t    timeNextUpdate = 0;
    time_t    timeNow, timeToday, timeTomorrow;
    struct tm tmNow,   tmToday,   tmTomorrow;
    int secondsDelay;
    do
        /* Find the current time in time_t and struct tm formats */
        timeNow = time(NULL);
        gmtime_r( &timeNow, &tmNow );
/* Create a tm structure and time_t which is the beginning of today UTC */
tmToday = tmNow;
tmToday.tm_hour = 0;
tmToday.tm_min = 0;
tmToday.tm_sec = 0;
timeToday = mktime( &tmToday );
/* Now create a tm structure and time_t which is the beginning of tomorrow UTC
Note we rely on the ability of mktime to notice month and year
changes to sort these out just from the addition of the day number */
tmTomorrow = tmToday;
tmTomorrow.tm_mday++;
timeTomorrow = mktime( &tmTomorrow );
/* Now update the observation number if the next update is before today
(the normal occurance) or after tomorrow (indicating that a time error
has occurred in the last iteration */
if (timeNextUpdate <= timeToday || timeNextUpdate > timeTomorrow )
DHS_ID pDrv = &dhsDrv;
dhsObsnum ( pDrv ); <--------------- or whatever you want it to run
timeNextUpdate = timeTomorrow;
/* Calculate the number of seconds left in today */
secondsDelay = 86400 - (tmNow.tm_hour*3600 + tmNow.tm_min*60 + tmNow.tm_sec);
taskDelay( secondsDelay * sysClkRateGet() );
} while (TRUE);
Obviously you can make it run at other times and other frequencies.
Aloha,
Maren
cron-type scheduling in database or sequencer? Kay-Uwe Kasemir
Prev: Re: cron-type scheduling in database or sequencer? Andrew Johnson
Next: Active-X and Epics Bill Nolan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
