1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
To: Andrew Johnson <[email protected]>, [email protected]
Date: Mon, 11 Sep 2006 10:18:20 -0400
Kate Feng wrote:
> Andrew Johnson wrote:
> > The PCIbus Retry and Disconnect cycle terminations that you discussed do
> > not actually stop the data transfer cycle completely, they only permit
> > it to be run again or to take longer to complete than a regular PCIbus
> > single I/O cycle.
> Yes, that's why the overhead is only needed for ISR and where interrupt is
> disabled.
I do'nt have the mvme6100 system setup for tests.   However, this is somthing
that could be verified via some tests.
Kate
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Prev: RE: EPICS: Visualization Dalesio, Leo `Bob`
Next: EPICS: trying to build asyn 4-6 David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Next: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
