So far, I have medm and edm built on my Linux system for displaying graphic data. MEDM supports animated GIFs, where the particular frame shown is selected by a PV. In fact you can use a Visibility PV on most widget types to control when the widget is visible or not, and then pile several different sets of widgets on top of each other with different visibility settings. EDM can do the visibility thing, and also supports a way of defining your own symbols which provide a way to show an object in a number of different states, selecting between the states by a PV again. This is probably easier to do than the visibility approach, once you understand how to create the symbol object. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
