1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS source Documentation
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 08 Sep 2006 11:45:20 -0500
David Dudley wrote:
Just a strange question, but I've noticed a tendency of all the
source files to not have any comments (or very few) in them regarding
what they do.
Is this a standard I've just never known about? Typically, source(s)
that I compose end up having as much in comments (or more) than in
code, for the simple reason that I can't concentrate on one component
at a time, and I might work some now, and some two or three days from
now (and I've slept between then and now).
I think a lot of it relates to the personal coding style of the original author(s) of EPICS Base. If you look at code from other people such as device support modules you'll see more comments.
I get so busy with the multiple things I have to do, that if I don't
comment the hell out of what I write, I might have to spend quite a
bit of time decoding what I was doing before I needed to switch.
Is this the normal style for EPICS, or would there be any objections
to comments being added to some of the files as I work with/on them?
Personally I'm in favor of including comments where they contribute to understanding what the code is trying to accomplish or as a reminder that there's something going on here which might not be immediately obvious. I also try to choose routine and variable names that are self exdplanatory, since that reduces the number of comments that are needed (please don't try and use Hungarian notation in names, even the original 'sensible' version).
I don't think we're likely to remove any comments from the code you submit so don't worry about including comments that you feel are useful.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
EPICS source Documentation David Dudley
Prev: RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Dalesio, Leo `Bob`
Next: "Best Pratice" on Monitors Bill Nolan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Gurd, Pamela A.
Next: Re: EPICS source Documentation Paul Joireman
