Welcome to the EPICS community. David Eisert wrote: I am trying to build 3.14.8.2 on QNX 6.1 (GCC version 2.95.2). We are currently running our control system You're going to have to port EPICS to QNX then, since we don't have the operating system interface for that OS in Base. There may not be too much work needed to do this, but it will take some effort. Unfortunately the build is failing in resourceLib.h. I noticed that the code near the error has a problem on In the build output that you presented though the problem is with the build for the host machine though, not the QNX cross-compile. You said: I am building it using the linux-x86 host architecture. So far only small changes The part of the error message I'm interested in is this: make[3]: *** [fdmgr.o] Error 1 This tells me that the build failed while it was trying to compile code that will run on Linux, not code that will run on QNX (which would have been an error from inside some libCom/O.qnx-XXX directory). The EPICS build system was designed to compile multiple architectures simultaneously alongside themselves, and the O.linux-x86 directory tells me that the error was reported while building code for linux. You actually *have* to be able to compile code for the host architecture as well as for the target architecture, since there are programs in the early parts of the build that are run while building later parts of the code, thus you must have a host compiler as well as the cross-compiler present to build EPICS. Please post the output from the following command: /usr/bin/g++ --version This should *not* be your QNX cross-compiler, it must be the compiler for the host Linux operating system. What Linux distribution are you building this on? - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
