Kay-Uwe Kasemir wrote: On Sep 6, 2006, at 02:30 , Jon Brinkmann wrote:
I will tell a long-winded story, the upshot of which is that I believe that a minimal extension to StripTool, combined with the (complimentary) SNS scope tool, could usefully address the vast majority of waveform display applications.... Of course, talk is cheap, and I am not actually volunteering to do any real work. I am only offering to share experience, and let others decide whether there is something broadly palatable worth pursuing... -- Larry
The conclusion we arrived at is essentially identical to what Kay described. We decided to attack the problem as follows: 1) For some systems, we created (the RHIC equivalent of) a "time info" record, with fields describing the characteristics of the waveform (much as Kay describes). E.g. one field puts the data into one of those categories Kay enumerates, one field describes the time of the waveform "trigger", another describes the position of the trigger within the waveform (beginning, end, somewhere in the middle), another provides the inter-sample timing, etc. We probably went overboard, including fields like "signal bandwidth" (to describe a correlation window for data with different collection characteristics), and handling the case of multi-segment data (e.g. data acquired on multiple, separate triggers, but reported in a single waveform). We then made the RHIC equivalent of StripTool (General Purpose Monitor) sensitive to this information, so it could sensible display data from different sources. Obviously, populating, maintaining, and verifying such records requires effort, so we only used this technique for high-multiplicity, well-defined, and commonly used data sources (e.g. ramping magnet power supplies, loss monitors, etc.). Note also that one could use a relational database or plain files to store the same information. In any case, there needs to be some way of relating the waveform record to the "time info" record (if it exists). We chose the (unsophisticated) technique of using a name extension (i.e. "time info" record name is the record name with a ".timeInfo" extension). It works, but I am sure there are better ways to make that association. 2) General Purpose Monitor (GPM) also allows users to *manually* define the salient time characteristics of a signal when that signal is added to the display. These configurations can be saved between invocations of GPM. This technique is best suited for highly dynamic, ad-hoc situations. If the signal characteristics were more stable, they should be addressed by technique #1. 3) As a default, because *something* is better than *nothing*, GPM was designed to display waveforms even in the absence of any information describing the time characteristics of the waveform. StripTool could easily be enhanced in a similar way. GPM uses one of two techniques: A) If a new waveform arrives within some time threshold of the previously published waveform, the data is presented with each waveform element evenly distributed in time. This ends up working well for us, because it is common for us to do things like collect 720Hz magnet power supply data which is "published" at 1Hz. In that case, the data is displayed as it each waveform element were separately published at 720Hz. GPM assumes that the waveform timestamp applies to the first element. B) If waveforms arrive "infrequently", some default inter-sample time is used, based on the length of the waveform. I.e. if waveforms of length 10,000 come every 4.5 seconds, GPM might decide that the inter-sampling rate is 10KHz, but if the waveform were of length 100, it might assume 720Hz (a common timebase at RHIC). Obviously, these heuristics are far from fool-proof, and have resulted in some peculiar displays (data "spread out" when it should not be, or data "compressed" when it should not be). Nevertheless, I have found it surprisingly useful, especially if the alternative is no display at all. Even binary data such as raw video can be meaningfully displayed with GPM! HTH
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
