No, the arguments to the rset->special() routine are the DBADDR for the field that is being written to, and the pass (0 before, 1 after the actual put operation). However if there's more than one element in the buffer and the field is marked as special, immediately after calling rset->special() the rset->get_array_info() routine is called to get the offset value (for appending data to circular buffers), and after changing the array the rset->put_array_info() routine is also called to tell it how big the request was. Unfortunately this doesn't seem to provide any way to reject a put based on size if that's what you're trying to do. The code that implements this is dbPut() in src/db/dbAccess.c which should be reasonably easy to follow. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
