Just my £0.02 worth of thoughts on the topic of Qt/EPICS GUI...
Is this new Qt version of EDM a re-implementation of EDM, using Qt or is it a new set of CA-aware Qt widgets to use with Qt's fantastic "designer"?
I do favour the idea of taking advantage of the existing designer application from Trolltech and _just_ create a set of CA aware widgets (inherit most parts from the existing Qt widgets).
If done carefully, the designer can be used in almost the same simple way as EDM: you dump your widgets on a form, set the PV properties, compile and run. There should be no need to get into the C++ code - but the option is there if special requirements exists...
If a Python interface is then made for the Qt/CA widgets, even the compilation step can be taken out of the process...
About compatibility with EDM: the output format from designer is an XML description of the GUI. It should be possible to write a script that can parse the EDM/MEDM files and output a similar XML format which can be used by Qt/designer.
Cheers,
Ulrik
Ulrik Pedersen phone: +44(0)1235-778580
Software Engineer email: [email protected]
Diamond Light Source Ltd.
Rutherford Appleton Laboratory,
Chilton, Didcot
OxfordShire OX11 0DE
- Re: Fedora Core 6 to drop OpenMotif Ernest L. Williams Jr.
Re: Device with INP as a PV_LINK Tim Mooney
A question concerning rset->special() Benjamin Franksen
<2006>
Re: Fedora Core 6 to drop OpenMotif Benjamin Franksen
EPICS in VMEbus Systems magazine! Lawrence T. Hoff
<2006>
