The problem with the fallback solution that you propose is that it will only work with some drivers, and not with any that make use of the vxWorks network stack because the network gets shutdown before any regular rebootHook routines are called. A site that really can't modify their BSP can put the following (untested) line in their st.cmd file instead: rebootHookAdd(epicsExitCallAtExits) I think our position should be that any site that wants the proper cleanup behaviour should install the BSP patch. Adding the qualifier "but if you don't have any network devices you don't need to" will just cause the site to have to solve the problem at a later date when they *do* add a network device. IMHO the right place to fix the problem is to force it to come up early, rather than adding code to work around it that doesn't completely solve it. We have other facilities in EPICS that don't work on an unpatched vxWorks BSP: * the 'veclist' command won't show anything useful on most unmodified PowerPC BSPs because it uses intVecGet() which is not implemented by the WRS BSPs (in this case though it's not that useful even on a modified BSP since it can only show the first ISR in the chain for each interrupt vector; I would like to remove veclist completely from EPICS, its functionality really belongs in the BSP). * The devLibA24Malloc subsystem relies on BSP provided routines on CPUs which don't export the whole of RAM to the A24 space (which covers every current VME CPU board from Motorola); this subsystem probably isn't used much any more, but it is a documented part of devLib that is needed for some hardware to work. However I realize that my position may seem a bit hard-line, and if the concensus reached by discussion here is to install Eric B's workaround I will do so. Discuss... (but enjoy the Labor Day weekend first if you're in the US!) - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
