1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: OSI Replacement for rebootHookAdd ???
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 1 Sep 2006 15:15:36 -0600
On Sep 1, 2006, at 2:08 PM, Andrew Johnson wrote:
Eric Bjorklund wrote:
2. Would it be reasonable for the vxWorks hook (atReboot.cpp) to register with rebootHookAdd if it did not find sysAtReboot in the symbol table? (at least then I could get my cards disabled -- and I don't really care about the order).
Are you reluctant or unable to add the sysAtReboot mechanism to your BSPs? The message describing the required change is at http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php
Personally, no, I am neither reluctant or unable. But I am working on drivers that will be distributed to lots of other sites (which is why I am in to portability these days) and I can't vouch for their situations. Plus there is just the general inelegance of requiring a special BSP patch in order for our "portable" routines to run.
So I guess the question remains -- would it be reasonable to register the exit handler with rebootAddHooks in the event that sysAtReboot is not found?
-Bj
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031 email: [email protected]
TSPA :: DUSA=ADTO
Re: OSI Replacement for rebootHookAdd ??? Andrew Johnson
OSI Replacement for rebootHookAdd ??? Eric Bjorklund
Prev: Re: OSI Replacement for rebootHookAdd ??? Andrew Johnson
Next: Re: OSI Replacement for rebootHookAdd ??? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
