Andrew Johnson wrote:
> >>This doesn't mean that the existing drivers won't work; the vast
> >>majority of the time they will be fine. They will not be robust in the
> >>presence of unexpected bus errors though.
> > And this problem rises only if the mvme6100 is used as a
> > system controller. It will be fine if it's used a non system
> > controller.
> No, that is incorrect. The problem relates to the onboard interface
> between the CPU, its local PCI bus and the PCI to VME bridge chip; it is
> not at all related to whether the VME interface chip is acting as the
> VMEbus system controller or not.
I meant if one use mvme5500 as the system controller, and mvme6100 as a
2nd CPU. In this case, mvme5500 is a VME master. In your message :
http://www.aps.anl.gov/epics/tech-talk/2006/msg00887.php
It stated that "If the transaction was a VMEbus read, the VME Master
completes the Linkage Module command by
filling the buffer with a data pattern of all ones. " This only applies
if the master CPU used the Tsi148 chip.
I am sorry, but I had trouble in obtaining the document for the Tsi148.
I had E-mail them since last week.
Kate
> - Andrew
> There is considerable overlap between the intelligence of the smartest
> bears and the dumbest tourists -- Yosemite National Park Ranger
- Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
- Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
RE: VME Bus Error handling on MVME3100 and MVME6100 boards Thompson, David H.
<2006>
<2006>
