We could implement the Ethereal decoder in such a way that the user would set a list of port numbers for the CA protocol in case non-default ports are in use. Since different port numbers typically designate different systems, it might also make sense to give human-readable names to these ports, and show this text as a special field, which could then also be used for filtering, searching and in packet info display. The reasons for these non-standard ports aside, I have a question about how the CA packets will be recognized. Will it be purely based on source/destination port, or some other header in the packet? If it will be based solely on ports, do you foresee the ability to customize the ports associated with the CA protocol in the proposed CA ethereal plug-in? CA packets can not be reliably identified by other means than by port numbers (e.g., they don't contain magic codes or anything of the sort). As said above, the port numbers would thus be customizable to cover your case. As a side note, do other labs use non-standard CA ports, or are we on our own here? At Cosylab we also use non-default ports to ensure isolation of systems. Cheers, Rok
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
