1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VCCT and CA sniffer
To: Rok Sabjan <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 23 Aug 2006 11:34:44 -0700
Rok--
First off, I'm no ethereal expert, but have used it in attempts to diagnose
possible CA network problems. Any add-on or plug-in specific to CA packets
would seem to be a great addition.
However, in the ISAC Controls system at TRIUMF we use non-standard ports
for the main ISAC Control system. Beyond that we also use different ports
from our main, non-standard ports for some of the secondary systems (yes, it
can get confusing).
The reasons for these non-standard ports aside, I have a question about how
the CA packets will be recognized. Will it be purely based on
source/destination port, or some other header in the packet? If it will be
based solely on ports, do you foresee the ability to customize the ports
associated with the CA protocol in the proposed CA ethereal plug-in?
As a side note, do other labs use non-standard CA ports, or are we on our own
here?
Cheers
Chris
Chris Payne			ISAC Operations Controls System Manager
"Relax Snap, this is particle physics, not rocket science."
On Tue, Aug 22, 2006 at 05:34:39PM +0200, Rok Sabjan wrote:
> Date: Tue, 22 Aug 2006 17:34:39 +0200
> From: Rok Sabjan <[email protected]>
> User-Agent: Thunderbird 1.5.0.5 (Windows/20060719)
> To: Matthieu Bec <[email protected]>
> Cc: Ned Arnold <[email protected]>, EPICS tech-talk <[email protected]>
> In-Reply-To: <[email protected]>
> Hi Ned, Matthieu et al.,
> thanks for the interest. I asked our expert what would be the benefits
> and here is his answer:
> In addition to only filtering CA traffic, the plug-in for Ethereal would
> also be able to 'dissect' the CA packet, that is, give meaning to the
> plain hex-codes. Thus, every CA packet would have fields revealing
> CA-specific information, such as:
>  * what CA command is in a packet (CA_PROTO_SEARCH,
> CA_PROTO_READ_NOTIFY, ...)
>  * what are the parameters of the command (channel name being sought
> for, channel name that was resolved, the value of the field that was
> returned, ...)
> Then, filtering and searching operations could also be made relative to
> those fields. Example filter:
>   "find all packets that concern record ABCD"
> I hope this is interesting enough. If you need additional information,
> please let me know.
> Best regards,
> Rok
Re: VCCT and CA sniffer Emmanuel Mayssat
Re: VCCT and CA sniffer Rok Sabjan
Re: VCCT and CA sniffer Ned Arnold
Re: VCCT and CA sniffer Matt Bickley
Re: VCCT and CA sniffer Ernest L. Williams Jr.
Re: VCCT and CA sniffer Matthieu Bec
Prev: Re: MAXv Multi-Axis Motion Controller in use? Jens Eden
Next: NetBSD: implementation of "osiSockDiscoverInterfaceAddresses()" David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VCCT and CA sniffer Brad Cumbia
Next: Re: VCCT and CA sniffer Emmanuel Mayssat
