On Wed, 2006-08-23 at 08:45 -0700, Steve Lewis wrote:
> Does anyone have experience using (and drivers for) the ICS-145
> 32-channel, 16-bit, 20 MHz digitizer?
Sure. The SNS actually used the ICS 145 for a beam diagnostics
emittance application. Carl Lionberger is the original author.
If you want, we can get you a copy from our CVS. :)
> Our engineer particularly
> likes its electrical characteristics, and intends to use the
> companion ICS-141 filter and programmable-gain board. (Any use of
> this one?) Note that the combination would limit the bandwidth to
> about 1 MHz.
> This is a change in requirements (fewer channels, higher bandwidth)
> from the original request to tech-talk, to which many of you
> responded with very usable solutions...thanks again.
- Any EPICS support for ICS 145? Steve Lewis
RE: MAXv Multi-Axis Motion Controller in use? Mark Rivers
<2006>
NetBSD: implementation of "osiSockDiscoverInterfaceAddresses()" David Dudley
<2006>
