Would that account for the inability to read data from any of the defined channels?
'dbl' lists the channels, and 'dbnr' gives counts of the channel types, but I can't access any data from the records. You should be able to use 'dbpr <recordname>, <level>' to see the record field values (level goes from 0 to 4) and watch them changing, which will prove that the database scanning is working. Please cut/paste the output from 'casr 2' which may give some more clues with the CA problem. The build works without error now, building the .so files with no problem on 3.14.8.2, but can't pass the RTEMS or libCom/test directories on the CVS download. Haven't worked on that problem yet....
The libCom/test area won't build from the CVS trunk at the moment, although it should do from the R3.14 branch snapshot. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists. -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
