> When I run it, it says "The CA server's beacon address list was empty
> after initialization?"
Possible causes:
O you have a non-default configuration that results in an empty beacon
address list - see the ca reference man
O no network interfaces installed in this host
O issues with os dependent bits of osiSockDiscoverBroadcastAddresses -
possibly with the os dependent implementation of ifreq_size ().
Jeff
> -----Original Message-----
> From: David Dudley [mailto:[email protected]]
> Sent: Tuesday, August 22, 2006 4:23 PM
> To: [email protected]
> Subject: Re: Setting option flags for building system libraries
> Actually, if I had read Janet's excellent directions further (and with my
> glasses on this time...), I would have found the single variable I needed.
> The build works without error now, building the .so files with no problem
> on 3.14.8.2, but can't pass the RTEMS or libCom/test directories on the
> CVS download. Haven't worked on that problem yet....
> I successfully built the sample application using makeBaseApp.pl, and it
> compiles and runs.
> after initialization?", which I'm assuming is wrong.
> I can do a 'dbl' and I see a list of records, however.
> When I try to do a 'dbpr' on any of them, I get "dbNametoAddr failed", so
> I assume there is a problem.
> But anyway - it didn't lock the machine up!
> David
> >>> Andrew Johnson <[email protected]> 08/22/06 4:58 PM >>>
> Hi David,
> David Dudley wrote:
> > 1. To build a relocatable library for libCom, I have to pass options
> > "-shared -fPIC" through to g++ when I'm creating the relocatable
> > library. This works fine, and I can create and use the library sort
> > of successfully. I'm still looking for the exact variable to set to
> > pass these values. have tried setting about every variable in my new
> > "CONFIG.Common.netbsd-x86" file, and currently have it set in
> > COMPILER_LDFLAGS. However, when I run gmake with these options
> > selected in COMPILER_LDFLAGS, it will create a properly library, but
> > fails to create a proper executable.
> > 2. To build an executable, I have to be sure NOT to pass the
> > "-shared" option through to g++. I demonstrated that this works by
> > deleting the incorrectly build 'antelope' program that is linked
> > after the library is built, delete the "-shared" flag from my new
> > "CONFIG.Common.netbsd-x86" file and rerun gmake. This will recreate
> > the antelope program, which appears to be functional.
> Hmm, I think there may be a problem here which means you might not be
> able to create shared libraries for NetBSD. Can I make sure I'm
> understanding your point first though:
> 1. To compile code for a .so, you *must* pass '-shared' to the gcc or
> g++ command line when you compile the .c/.cc/.cxx file.
> 2. To compile code for an executable (and presumably for a lib.a file),
> you *must* *not* pass '-shared' to the gcc/g++ command line.
> If those statements are both correct, I think you're going to have to
> disable the building of shared libraries since I believe we have no way
> to recompile a source file with different options to generate two
> different .o files from the same source.
> You can disable building shared libraries by setting SHARED_LIBRARIES=NO
> in your CONFIG.Common.netbsd-x86 file. I would recommend that you do
> that anyway for now and come back to the .so problem later.
> > Looks like most of the Make files were done by jba (I'm taking that
> > to be Janet Anderson, I hope... She still doing work on this, or
> > anyone have a suggestion?
> Yes, JBA is Janet Anderson <[email protected]> who is responsible for the
> build system.
> David Dudley wrote:
> > Well, I'm sure it won't run correctly, but ***IT COMPILES WITHOUT
> ERRORS***!
> Congratulations! I assume you ignored or disabled the .so builds to get
> to this point.
> - Andrew
> There is considerable overlap between the intelligence
> of the smartest bears and the dumbest tourists.
> -- Yosemite National Park Ranger
- Re: Setting option flags for building system libraries David Dudley
Re: VCCT and CA sniffer Rolf Keitel
Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
<2006>
RE: Setting option flags for building system libraries David Dudley
<2006>
