Actually, if I had read Janet's excellent directions further (and with my glasses on this time...), I would have found the single variable I needed.
The build works without error now, building the .so files with no problem on 3.14.8.2, but can't pass the RTEMS or libCom/test directories on the CVS download. Haven't worked on that problem yet....
I successfully built the sample application using makeBaseApp.pl, and it compiles and runs.
When I run it, it says "The CA server's beacon address list was empty after initialization?", which I'm assuming is wrong.
I can do a 'dbl' and I see a list of records, however.
When I try to do a 'dbpr' on any of them, I get "dbNametoAddr failed", so I assume there is a problem.
But anyway - it didn't lock the machine up!
David
>>> Andrew Johnson <[email protected]> 08/22/06 4:58 PM >>>
Hi David,
David Dudley wrote:
> 1. To build a relocatable library for libCom, I have to pass options
> "-shared -fPIC" through to g++ when I'm creating the relocatable
> library. This works fine, and I can create and use the library sort
> of successfully. I'm still looking for the exact variable to set to
> pass these values. have tried setting about every variable in my new
> "CONFIG.Common.netbsd-x86" file, and currently have it set in
> COMPILER_LDFLAGS. However, when I run gmake with these options
> selected in COMPILER_LDFLAGS, it will create a properly library, but
> fails to create a proper executable.
> 2. To build an executable, I have to be sure NOT to pass the
> "-shared" option through to g++. I demonstrated that this works by
> deleting the incorrectly build 'antelope' program that is linked
> after the library is built, delete the "-shared" flag from my new
> "CONFIG.Common.netbsd-x86" file and rerun gmake. This will recreate
> the antelope program, which appears to be functional.
Hmm, I think there may be a problem here which means you might not be
able to create shared libraries for NetBSD. Can I make sure I'm
understanding your point first though:
1. To compile code for a .so, you *must* pass '-shared' to the gcc or
g++ command line when you compile the .c/.cc/.cxx file.
2. To compile code for an executable (and presumably for a lib.a file),
you *must* *not* pass '-shared' to the gcc/g++ command line.
If those statements are both correct, I think you're going to have to
disable the building of shared libraries since I believe we have no way
to recompile a source file with different options to generate two
different .o files from the same source.
You can disable building shared libraries by setting SHARED_LIBRARIES=NO
in your CONFIG.Common.netbsd-x86 file. I would recommend that you do
that anyway for now and come back to the .so problem later.
> Looks like most of the Make files were done by jba (I'm taking that
> to be Janet Anderson, I hope... She still doing work on this, or
> anyone have a suggestion?
Yes, JBA is Janet Anderson <[email protected]> who is responsible for the
build system.
David Dudley wrote:
> Well, I'm sure it won't run correctly, but ***IT COMPILES WITHOUT ERRORS***!
Congratulations! I assume you ignored or disabled the .so builds to get
to this point.
- Andrew
There is considerable overlap between the intelligence
of the smartest bears and the dumbest tourists.
-- Yosemite National Park Ranger
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- RE: Setting option flags for building system libraries Jeff Hill
Re: Setting option flags for building system libraries Andrew Johnson
Re: VCCT and CA sniffer Rolf Keitel
<2006>
<2006>
