1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VME Bus Error handling on MVME3100 and 6100 boards
To: Tim Mooney <[email protected]>
Cc: "Ernest L. Williams Jr." <[email protected]>, Andrew Johnson <[email protected]>, EPICS tech-talk <[email protected]>
Date: Mon, 21 Aug 2006 11:16:51 -0700
On Thu, 2006-08-17 at 11:19 -0500, Tim Mooney wrote:
> Ernest L. Williams Jr. wrote:
> >>So, I have filed a technical concern with both Motorola and WindRiver.
> >>Of course, this will lead to TUNDRA but we need to get this resolved if
> >>we want to move forward and have reliability.
> >>I will post the results back here hopefully in the near future.
> > ========== Response from Motorola below ===============================
> > Motorola has received the fiollowing response from an engineer that was
> > involved with the TEMPE and from Tundra:
> > Tundra states that "the error handling with respect to a BERR
> > termination as a VMEbus master works as described in the Users Manual.
> > Tundra has no plans of changing this."  If the customer doesn't feel
> > that signaling via an interrupt is insufficient then we have no
> > recourse.  Please note that both Mac and Tundra agree that a failed read
> > of a valid VME address would likely occur only as a result of a
> > catastrophic system failure, i.e. the target board smoked.  The
> > probability that a failed read, when (or if) retried would return data
> > is essentially zero.
> > Not sure, what to make out of that initial response?
> "...failed read of a valid VME address..." suggests that they interpreted
> your concern differently than you intended.  Or maybe hardware guys just
> assume software developers are so good that no software would *ever* try to
> read something that isn't there.  Kind of flattering, yes, but I, for one,
> don't deserve that level of respect.  Anyway, the answer seems clear, even
> if their justification for it isn't quite on point.
It is - just extend the meaning of 'catastrophic system failure' to
triggering a software bug. In this case also: signalling via an
interrupt seems acceptable.
-- T.
VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and 6100 boards Ernest L. Williams Jr.
Re: VME Bus Error handling on MVME3100 and 6100 boards Tim Mooney
Prev: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Bill Nolan
Next: RE: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Tim Mooney
Next: RE: VME Bus Error handling on MVME3100 and 6100 boards Thompson, David H.
