1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VME Bus Error handling on MVME3100 and 6100 boards
Cc: Till Straumann <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 16 Aug 2006 18:42:10 -0400
On Wed, 2006-08-16 at 17:22 -0500, Andrew Johnson wrote:
> Till Straumann wrote:
> > On Thu, 2006-08-10 at 14:58 -0500, Andrew Johnson wrote:
> >> Interrupts may not be as quick at actually getting to the CPU as a
> >> Target Abort - I don't know whether modern CPUs finish off any/all
> >> instructions that they've already started running before they actually
> >> switch to processing the exception, but it's likely that there will be
> >> a number of instructions pending.  This also supposes that interrupts
> >> are enabled at the time the bus error gets flagged.
> > Yes, the latter is true. However, VME access is so slow that having
> > interrupts disabled around longer manipulations is not a good idea
> > anyways.
> It is sometimes impossible to write code that has to manipulate the
> interrupt registers of a VME slave card without disabling interrupts to
> the CPU.
> > Note that the 'machine check' generated by the target abort is also
> > just an external interrupt line. I can't see how that differs much
> > from using EE. On board designs using the universe, the target abort
> > is generated by the host bridge and propagated via the MCP or TSA
> > line to the CPU and therefore inherently asynchronous to instruction
> > execution also.
> The Machine Check exception generated by the Target Abort is synchronous
> with the termination of the read cycle that caused the VME bus error,
> and it is thus possible to determine the instruction that caused the
> fault.  For example, on an MVME2700 (Universe-2) with my BSP:
> mv2700> d 0xf0000000
> f0000000:
> VME Bus Error accessing A24: 0x000000
> machine check
> Exception next instruction address: 0x001ba5e0
> Machine Status Register: 0x0008b030
> Condition Register: 0x20004084
> Task: 0x1d3b1d0 "tShell"
> A disassembly shows the exception instruction:
> mv2700> l 0x001ba5d0
> 0x1ba5d0  3c60001f    lis         r3,0x1f # 31
> 0x1ba5d4  3ba10030    addi        r29,r1,0x30 # 48
> 0x1ba5d8  386302b4    addi        r3,r3,0x2b4 # 692
> 0x1ba5dc  a0090000    lhz         r0,0(r9)
> 0x1ba5e0  901e0004    stw         r0,4(r30)
> 0x1ba5e4  93010030    stw         r24,48(r1)
> 0x1ba5e8  a09e0006    lhz         r4,6(r30)
> 0x1ba5ec  4cc63182    crxor       crb6,crb6,crb6
> 0x1ba5f0  4bfe1b61    bl          0x19c150 # printf
> The instruction at 0x001ba5dc is the lhz instruction that tried to read
> the location at A24:000000
> >> If the Bus Error occurs inside an interrupt service routine,
> > I consider this a fatal, nonrecoverable error.
> I also consider it a pretty fatal error, but I want my hardware and OS
> to be able to tell me where it was when the problem occurred so I can
> quickly figure out what actually happened.
> > you're invariably gonna see more of this as CPUs get faster ;-)
> Actually CPUs have pretty much stopped getting faster nowadays (although
> the highest speeds haven't filtered through to the VME world yet); we're
> just putting them in parallel to achieve speedups now...
> > In any case, IMO, a bus error should be considered a serious error that
> > must be avoided (except for 'probing' during initialization)
> > because of the significant latencies that can be introduced
> > by a VME bus timeout.
> I'm not disputing that we should avoid bus errors, but they are a fact
> of life in a failing VME system.  Unfortunately the Tempe chip's flawed
> design makes the system's response to one much less than ideal, given
> that the Target Abort mechanism is available on the PCIbus and Tundra
> have already managed to implement the necessary circuitry to use it in
> the Universe-2 chip.
> > Of course, write operations are completely asynchronous
> > and in that case, the only thing that can be done is reporting
> > that an error happened but there is no way to relate it
> > to a particular task/PC.
> > Note that this is also true for the Universe (with write-posting
> > enabled).
> I am less concerned about write posting (I enable this myself) and even
> bus errors from write cycles, since they don't directly affect the
> operation of the running task and will almost always be surrounded by
> read cycles anyway so a card that develops a fault will soon signal its
> problem by faulting a read operation.
> What I object to is the completion of a failing read cycle with an
> all-1s bitpattern, because this can and probably will break any existing
> device drivers.  In the past a driver was guaranteed that a bus error on
> a read cycle would stop it immediately at the read instruction and thus
> prevent further operation, whereas now drivers will have to be very
> defensive about all the data they read from the VMEbus.
> That's not going to be good for performance or portability, especially
> where all-1's is a valid bitpattern from a register that must be read
> inside an ISR (how can the ISR tell whether the value it read was real
> or not?  The only way to find out is to ask the Tempe chip, so the code
> is no longer portable).
> > However, in contrast to the universe, write posting cannot be disabled
> > on the Tsi148 and that introduces problems with VME ISRs:
> > The only remedy here is reading something back from
> > the device prior to letting the ISR return (reading anything
> > flushes the tsi148's write-FIFO)
> This is actually something that all VME ISRs should be doing anyway,
> since even the VMEchip2 (as used on the MVME167 et al) implemented write
> posting.
> > => IMO,  the Tsi148's  new features
> >      (fast 2eVME and SST transfers among others)
> >      outweigh the disadvantage that write-posting
> >      cannot be disabled.
> >         I don't share your negative assessment and
> >      recommendation to stay away from 6100s.
> If you need the new features and speed then you'll probably be willing
> to recode any existing drivers or just accept that random things may
> happen in the event that some card fails.  For operational sites like
> the APS with 224 different types of VME card used in our IOCs,
> revisiting all our device drivers isn't something we want to have to do...
We are concerned about the VMEBus issues that you raised.
The MVME2100 will be End-of-Life (EOL) soon.  We are counting on the
MVME3100 and MVME6100 as successors.
So, I have filed a technical concern with both Motorola and WindRiver.
Of course, this will lead to TUNDRA but we need to get this resolved if
we want to move forward and have reliability.
I will post the results back here hopefully in the near future.
Ernest
SNS Control Systems Group
ORNL
> - Andrew
Re: VME Bus Error handling on MVME3100 and 6100 boards Andy Foster
Re: VME Bus Error handling on MVME3100 and 6100 boards Joe Sullivan
Re: VME Bus Error handling on MVME3100 and 6100 boards Ernest L. Williams Jr.
RE: VME Bus Error handling on MVME3100 and 6100 boards Thompson, David H.
VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Next: Re: looking for OSI version of epid record Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Andy Foster
