1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Devices Which Send Unsolicited Messages
To: "Steven Banks" <[email protected]>, <[email protected]>
Date: Fri, 4 Aug 2006 07:39:11 -0500
There is one example driver in asyn, testIPServerApp which handles unsolicited messages.  It functions as a simple "echo" program to send responses to an IP client.  It simply has a read pending all the time, i.e. a read with infinite timeout.
That approach won't work if you have a device that implements both typical command/reply syntax and ALSO sends unsolicited messages.  For that type of device here is what I would do:
1) Before each write, do a series of reads with 0 timeout to read any unsolicited messages that have arrived.  This reading could also be done periodically if it is important to read the unsolicited messages frequently.
2) Then do the write/read.  If you got an "incorrect response" because it was an unsolicited one, then do another read.
Another approach you might imagine is to replace step 1) with a read with an infinite timeout, and then cancel that request when one wants to do a write/read.  I believe this will NOT work, because asyn provides no mechanism to cancel a pending read or write operation in the low level drivers like serial or IP.  asyn's cancel request only cancels a request that is still in the asynManager queue, not a request that has already been delivered to the driver.  Is this correct Eric/Marty?
Sent: Fri 8/4/2006 4:57 AM
To: [email protected]
Subject: Devices Which Send Unsolicited Messages
This is a follow up question to a comment that Dirk Zimoch made in another
thread.
We use Asyn for almost all of our device drivers, however up till now none
of the devices we have used send unsolicited messages.   We live in fear
of the day when we encounter such a device because we don't know how to
handle these messages in Asyn.  In fact, Dirk commented that this is not
even supported in Asyn.  If this is true, what is the canonical method in
EPICS of writing a device driver which copes with such a device?
Steve Banks
Australian Synchrotron Project
Re: Devices Which Send Unsolicited Messages Eric Norum
Devices Which Send Unsolicited Messages Steven Banks
Prev: Devices Which Send Unsolicited Messages Steven Banks
Next: Re: Devices Which Send Unsolicited Messages Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
