Hi Doug,
I am running the same configuration as you (Cygwin make 3.80 and
Microsoft Visual Studio .NET 2003) and I am not having problems.
I am using base 3.14.8.2 and I just did "make clean uninstall" and then
"make" at the top level in base and it built fine.
Here is a little of the output when building src/dbStatic:
..\\..\\..\\bin\\win32-x86\\e_flex.exe
-S../../../include/flex.skel.static -8 ../dbLex.l
perl ../../../configure/tools/mv.pl lex.yy.c dbLex.c
move lex.yy.c into dbLex.c
perl ../../../configure/tools/rm.pl -f dbYacc.c y.tab.c
..\\..\\..\\bin\\win32-x86\\antelope.exe ../dbYacc.y
perl ../../../configure/tools/mv.pl y.tab.c dbYacc.c
move y.tab.c into dbYacc.c
cl -c /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /nologo
/D__STDC__=0 /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include dbYacc.c
So it was able to execute e_flex and antelope with no problems.
I run the build from the Cygwin bash shell. I am able to build for both
the "win32-x86" and "cygin32-x86" architectures.
I execute the following script when I want to build for win32-x86:
$ cat /usr/local/bin/setup_epics_win32
export EPICS_HOST_ARCH=win32-x86
export VSINSTALLDIR="C:\Program Files\Microsoft Visual Studio .NET
2003\Common7\IDE"
export VSINSTALLDIR_sh="/cygdrive/c/Program Files/Microsoft Visual
Studio .NET 2003/Common7/IDE"
export VCINSTALLDIR="C:\Program Files\Microsoft Visual Studio .NET 2003"
export VCINSTALLDIR_sh="/cygdrive/c/Program Files/Microsoft Visual
Studio .NET 2003"
export FrameworkDir=C:\WINDOWS\Microsoft.NET\Framework
export FrameworkDir_sh=/cygdrive/c/WINDOWS/Microsoft.NET/Framework
export FrameworkVersion=v1.1.4322
export FrameworkSDKDir="c:\Program Files\Microsoft Visual Studio .NET
2003\SDK\v1.1"
export FrameworkSDKDir_sh="/cygdrive/c/Program Files/Microsoft Visual
Studio .NET 2003/SDK/v1.1"
export DevEnvDir=$VSINSTALLDIR
export DevEnvDir_sh=$VSINSTALLDIR_sh
export MSVCDir=$VCINSTALLDIR/VC7
export MSVCDir_sh=$VCINSTALLDIR_sh/VC7
export
PATH="$DevEnvDir_sh:$MSVCDir_sh/BIN:$VCINSTALLDIR/Common7/Tools:$VCINSTA
LLDIR_sh/Common7/Tools/bin/prerelease:$VCINSTALLDIR_sh/Common7/Tools/bin
:$FrameworkSDKDir_sh/bin:$FrameworkDir_sh/$FrameworkVersion:/usr/bin/:/u
sr/local/bin:/usr/X11R6/bin/:/corvette/usr/local/epics/base/bin/win32-x8
6:/corvette/usr/local/epics/extensions_devel/bin/win32-x86"
export
INCLUDE="$MSVCDir/ATLMFC/INCLUDE;$MSVCDir/INCLUDE;$MSVCDir/PlatformSDK/i
nclude/prerelease;$MSVCDir/PlatformSDK/include;$FrameworkSDKDir/include"
export
LIB="$MSVCDir/ATLMFC/LIB;$MSVCDir/LIB;$MSVCDir/PlatformSDK/lib/prereleas
e;$MSVCDir/PlatformSDK/lib;$FrameworkSDKDir/lib"
I execute the following script when I want to build for cygwin32-x86:
$ cat /usr/local/bin/setup_epics_cygwin32
export
PATH="/usr/bin/:/usr/local/bin:/usr/X11R6/bin/:/corvette/usr/local/epics
/base/bin/cygwin-x86:/corvette/usr/local/epics/extensions_devel/bin/cygw
in-x86"
export EPICS_HOST_ARCH=cygwin-x86
export HOST_ARCH=cygwin-x86
I don't know what could be different between your system and mine.
Maybe the script that defines the PATH?
Cheers,
Sent: Tuesday, August 01, 2006 3:29 PM
To: [email protected]
Subject: RE: Problem building base 3.14.8.2 on Win32
I got a suggestion off-list to try
set MAKE_MODE=UNIX
(thanks Janet for that!).
This produces an interesting change. With that flag set the
make gets past this problem of launching antelope.exe.
However it fails very shortly after with "/bin/sh.exe" not
found, like this:
make -C softIoc install
make[2]: Entering directory
`/cygdrive/e/epics/base-3.14.8.2/src/softIoc'
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86
install
make[3]: Entering directory
`/cygdrive/e/epics/base-3.14.8.2/src/softIoc/O.win32
-x86'
make[3]: /bin/sh.exe: Command not found
Cygwin does of course contain "sh.exe" and it's on the path.
Clearing the MAKE_MODE flag and issuing make again (w/o a clean) doesn't
have this problem and the make runs on until it's time to run the next
executable and it fails again.
So right now I'm setting this flag, running make, watch it fail
on sh.exe, clear the flag, run make again, watch it fail at a later
point on an executable and repeat.
I think doing this I'll eventually get to the end of the build
but I'm wondering if someone has a better solution as this is slow and
painful (and of course I can never rebuild)?
I'm using "make" from Cygwin and I assume that's the root
problem here.
E:\epics\base-3.14.8.2>make -version
GNU Make 3.80
Copyright (C) 2002 Free Software Foundation, Inc.
Should I be using a different make or running it inside a bash
shell or something else?
Thanks a lot for everyone's help so far. I think we're getting
close here.
Doug
Sent: Tuesday, August 01, 2006 12:16 AM
Thanks Tanyshyam for the quick reply, but unfortunately I've
already applied the fix to RULES_BUILD. Without that the build fails at
the point of copying the executables.
With that fix the executables are copied and the make runs on
for a while but then it fails when it tries to execute antelope.exe.
I'll also attach more of the trace to give some more context to
where the build is failing (doing a "make clean uninstall" and then
"make" fails at the same point but with just a lot more compilation
steps happening).
Doug
make -C configure install
make[1]: Entering directory
`/cygdrive/e/epics/base-3.14.8.2/configure'
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86
install
`/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x
86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory
`/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x8
6'
make[1]: Leaving directory
make -C src install
`/cygdrive/e/epics/base-3.14.8.2/src'
make -C makeBaseApp install
`/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp'
install
`/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.w
in32-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
`/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.wi
n32-x86'
make -C makeBaseExt install
`/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt'
install
`/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.w
in32-x86'
`/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.wi
n32-x86'
make -C libCom install
`/cygdrive/e/epics/base-3.14.8.2/src/libCom'
install
`/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-
x86'
`/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-x
86'
make -C toolsComm install
`/cygdrive/e/epics/base-3.14.8.2/src/toolsComm'
make -C antelope install
`/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel
ope'
make -C O.win32-x86 -f ../Makefile TOP=../../../.. T_A=win32-x86
install
make[4]: Entering directory
ope/O.win32-x86'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory
`/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo
pe/O.win32-x86'
pe'
make -C flex install
`/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
install
`/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/
O.win32-x86'
perl ../../../../configure/tools/rm.pl -f parse.c y.tab.c
perl ../../../../configure/tools/rm.pl -f parse.h y.tab.h
..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command
not found
make[4]: *** [parse.c] Error 127
`/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O
.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[2]: *** [flex.install] Error 2
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src'
make: *** [src.install] Error 2
Sent: Monday, July 31, 2006 11:34 PM
To: Douglas Pearson
Cc: [email protected]
Subject: Re: Problem building base 3.14.8.2 on Win32
during build it copies exe and required dll and obj in bin as
well as O.win32-x86 directory...i think
you have to modify some files in configure to do it correctly
under windows as follows
1.base-3.14.8.2\configure\RULES_BUILD
line no 330
ifdef WIN32
ifdef BORLAND
@$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)
else
@$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)
endif
endif
2.base-3.14.8.2\configure\os\CONFIG_SITE.win32-x86.win32-x86 to
select proper compiler
you may encounter some other problem in makeBaseApp.pl.but clear
it first
thnaks
tanushyam
TANUSHYAM BHATTACHARJEE
SCIENTIFIC OFFICER
VARIABLE ENERGY CYCLOTRON CENTRE
1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64
email:[email protected]
Phone #23371230/31/32/33/34 Extn: 2304
Fax: 91 33 3346871
----- Original Message -----
Date: Tuesday, August 1, 2006 6:14 am
Subject: Problem building base 3.14.8.2 on Win32
> I'm trying out EPICS for the first time and
trying to build it on
> Windows.After seeing the posts about Visual Studio 8 (2005),
I've
> switched to using
> Visual Studio 7 (.NET 2003) and made the change to
> configure/RULES_BUILD as
> described in the known issues.
> With that I've got everything to build and com.dll even
installs
> itself now.
> However, the next error I'm getting is:
not
> foundmake[4]: *** [parse.c] Error 127
> .win32-x86'
> The odd thing i! s that an
- RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
<2006>
<2006>
