1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem building base 3.14.8.2 on Win32
To: <[email protected]>
Date: Tue, 1 Aug 2006 13:28:48 -0700
I got a suggestion off-list to try
set MAKE_MODE=UNIX
(thanks Janet for that!).
This produces an interesting change.  With that flag set the make gets past this problem of launching antelope.exe.
However it fails very shortly after with "/bin/sh.exe" not found, like this:
make -C softIoc install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/softIoc'
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/softIoc/O.win32
-x86'
make[3]: /bin/sh.exe: Command not found
Cygwin does of course contain "sh.exe" and it's on the path.  Clearing the MAKE_MODE flag and issuing make again (w/o a clean) doesn't have this problem and the make runs on until it's time to run the next executable and it fails again.
So right now I'm setting this flag, running make, watch it fail on sh.exe, clear the flag, run make again, watch it fail at a later point on an executable and repeat.
I think doing this I'll eventually get to the end of the build but I'm wondering if someone has a better solution as this is slow and painful (and of course I can never rebuild)?
I'm using "make" from Cygwin and I assume that's the root problem here.
E:\epics\base-3.14.8.2>make -version
GNU Make 3.80
Copyright (C) 2002  Free Software Foundation, Inc.
Should I be using a different make or running it inside a bash shell or something else?
Thanks a lot for everyone's help so far.  I think we're getting close here.
Doug
Sent: Tuesday, August 01, 2006 12:16 AM
To: [email protected]
Thanks Tanyshyam for the quick reply, but unfortunately I've already applied the fix to RULES_BUILD.  Without that the build fails at the point of copying the executables.
With that fix the executables are copied and the make runs on for a while but then it fails when it tries to execute antelope.exe.
I'll also attach more of the trace to give some more context to where the build is failing (doing a "make clean uninstall" and then "make" fails at the same point but with just a lot more compilation steps happening).
Doug
make -C configure install
make[1]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/configure'
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x
86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x8
6'
make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/configure'
make -C src install
make[1]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src'
make -C makeBaseApp install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp'
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.w
in32-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.wi
n32-x86'
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp'
make -C makeBaseExt install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt'
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.w
in32-x86'
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.wi
n32-x86'
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt'
make -C libCom install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom'
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-
x86'
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-x
86'
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom'
make -C toolsComm install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm'
make -C antelope install
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel
ope'
make -C O.win32-x86 -f ../Makefile TOP=../../../.. T_A=win32-x86 install
make[4]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel
ope/O.win32-x86'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo
pe/O.win32-x86'
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo
pe'
make -C flex install
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
make[4]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/
O.win32-x86'
perl ../../../../configure/tools/rm.pl -f parse.c y.tab.c
perl ../../../../configure/tools/rm.pl -f parse.h y.tab.h
..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not found
make[4]: *** [parse.c] Error 127
make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O
.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
make[2]: *** [flex.install] Error 2
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src'
make: *** [src.install] Error 2
Sent: Monday, July 31, 2006 11:34 PM
To: Douglas Pearson
Cc: [email protected]
Subject: Re: Problem building base 3.14.8.2 on Win32
during build it copies exe and required dll and obj in bin  as well as O.win32-x86 directory...i think
you have to modify some files in configure to do it correctly under windows as follows
1.base-3.14.8.2\configure\RULES_BUILD
line no 330
ifdef WIN32
ifdef BORLAND
@$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)
else
@$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)
endif
endif
2.base-3.14.8.2\configure\os\CONFIG_SITE.win32-x86.win32-x86 to select proper compiler
you may encounter some other problem in makeBaseApp.pl.but clear it first
thnaks
 tanushyam
TANUSHYAM BHATTACHARJEE
SCIENTIFIC OFFICER
VARIABLE ENERGY CYCLOTRON CENTRE
1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64
email:[email protected]
Phone #23371230/31/32/33/34 Extn: 2304
Fax: 91 33 3346871
----- Original Message -----
Date: Tuesday, August 1, 2006 6:14 am
Subject: Problem building base 3.14.8.2 on Win32
> I'm trying out EPICS for the first time and trying to build it on
> Windows.After seeing the posts about Visual Studio 8 (2005), I've
> switched to using
> Visual Studio 7 (.NET 2003) and made the change to
> configure/RULES_BUILD as
> described in the known issues.
> With that I've got everything to build and com.dll even installs
> itself now.
> However, the next error I'm getting is:
> foundmake[4]: *** [parse.c] Error 127
> .win32-x86'
> The odd thing i! s that an
RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
Prev: RE: How to change medm windows title + windows manager Rowland, J (James)
Next: RE: Problem building base 3.14.8.2 on Win32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
