1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problem building base 3.14.8.2 on Win32
To: <[email protected]>
Date: Mon, 31 Jul 2006 17:44:10 -0700
I'm trying out EPICS for the first time and trying to build it on Windows.  After seeing the posts about Visual Studio 8 (2005), I've switched to using Visual Studio 7 (.NET 2003) and made the change to configure/RULES_BUILD as described in the known issues.
With that I've got everything to build and com.dll even installs itself now.
However, the next error I'm getting is:
..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not found
make[4]: *** [parse.c] Error 127
make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O
.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
The odd thing is that antelope.exe is built and sitting in bin\win32-x86 and it seems to run OK.  Also if I manually cd down into the O.win32-x86 directory and run the command above it seems to run (although there's no obvious output -- not sure if that's OK or not).
Can anyone suggest what's wrong?
Doug
make is GNU make 3.80 from cygwin
perl is perl5.8.7 from cygwin
compiler is VS.NET 2003 Pro
OS is Windows XP SP2.
Prev: Re: Could not connect to EPICS home most of the time Ralph Lange
Next: Re: Could not connect to EPICS home most of the time btanu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: incorrect time stamp for one record in an IOC Mark Rivers
Next: Re: Problem building base 3.14.8.2 on Win32 btanu
