Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: build multiple tops?
From: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
To: Geoff Savage <dgsavage@wideopenwest.com>
Cc: TECHTALK <tech-talk@aps.anl.gov>
Date: Fri, 28 Jul 2006 10:34:09 -0700
In my case, I use environment variable and "gmake -e" to overwrite make
variables and settings located in configure/RELEASE.
The reason I use this make option is exactly for the same purpose you
want to use it: "easy" upgrade of epics release or many builds of same
epics release.
FYI,
Emmanuel
On Fri, 2006-07-28 at 12:00 -0500, Geoff Savage wrote:
> Hi,
> When I use a new epics release I need to go into each top area,
> modify the configure/RELEASE file, do an uninstall, and then gmake.
> Are there Makefile rules available to simplify this process?
> Thanks,  Geoff
build multiple tops? Geoff Savage
Prev: build multiple tops? Geoff Savage
Next: Moxa N-Port, ASYN and IOC Exit John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: Re: build multiple tops? Andrew Johnson
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
