Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: dol->name
To: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
Cc: epics <tech-talk@aps.anl.gov>
Date: Wed, 26 Jul 2006 09:45:41 -0500
Emmanuel Mayssat wrote:
Hello,
I would like to print the field name that is in the DOL.
What are all the fields for the structure pao->dol?
pao->dol.type --- ok
I could not find this information in the header file.
My understanding is that the epics database DOL are DBF_INLINK.
Where is the associated structure?
See link.h for the different structure definitions. pao->dol is a struct link which is typedef'd to DBLINK. You should check dol.type which for a DOL field at runtime should only ever be CONSTANT, DB_LINK or CA_LINK, and use the appropriate member in the union value to get the field value - you'll only need to use the constantStr or pv_link members. If you want to see some code that does this, look at the function dbGetString() in base/src/dbStatic/dbStaticLib.c.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
dol->name Emmanuel Mayssat
Prev: Re: dol->name Tim Mooney
Next: Allen-Bradley VME Scanner Module 6008 Luchini, Kristi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: communication with rs485 multidrop device and command/response protocol btanu
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
