Hi:
I have some problems of communication between an IOC and a client,
both
running on different machines on the same subnetwork on a similar
environment (Epics v 13.4.7 under linux redhat 9.0 kernel 2.4.20-8).
At the beginning of the startup of the IOC, process variable
values can
be got without problems from a client (either a simple command
line or a
php script), but after a while, the data is not available any more
and
the following message shows up on the IOC side :
CAS: request from 192.168.101.21:55894 => "bad resource ID"
Are there some pure-Java-CA-clients involved?
Does PHP use the pure Java client, or the C/C++ CA client?
I've seen "bad resource ID" messages on IOCs that were
accessed by the pure java CA client. For what it's worth,
they looked like this:
CAS: request from 172.31.75.12:34983 => "bad resource ID"
CAS: Request from 172.31.75.12:34983 => cmmd=1 cid=0x756 type=20
count=1 postsize=16
CAS: Request from 172.31.75.12:34983 => available=0x6b4 N=0 paddr=0x0
CAS: forcing disconnect from 172.31.75.12:34983
CAS: request from 172.31.75.12:35274 => "bad resource ID"
CAS: Request from 172.31.75.12:35274 => cmmd=1 cid=0x895 type=20
count=1 postsize=16
CAS: Request from 172.31.75.12:35274 => available=0x81a N=0 paddr=0x0
CAS: forcing disconnect from 172.31.75.12:35274
-Kay
CAS: Request from 192.168.101.21:55894 => cmmd=12 cid=0xffffffff
type=0
count=0 postsize=0
CAS: Request from 192.168.101.21:55894 => available=0x1 N=0
paddr=(nil)
CAS: forcing disconnect from 192.168.101.21:55894
Would someone have an idea of what's going on ?
I have no guesses at this point, but instead a few questions.
O Is this Linux running on a typical Intel x86 computer?
O What does the output from the "casr 10" command, typed into the
IOC's
console when the failure is occurring, provide?
O I would also look at the cpu, memory, and socket consumption in
the IOC's
host using top and netstat.
O Is 192.168.101.21 the IP address of the host for the client that
isn't
able to connect, or does the host IP in the message vary?
O Does the IOC appear to be functioning correctly in other respects
when
this occurs?
O Does the IOC have any layered products (such as drivers)
installed when
this occurs?
Jeff
-----Original Message-----
Sent: Monday, July 17, 2006 6:08 AM
To: [email protected]
Subject: CA communication problems
Hello,
both
values can
line or a
and
type=0
count=0 postsize=0
paddr=(nil)
Thanks for your help
Christophe
- RE: CA communication problems Jeff Hill
Re: CA communication problems Christophe Moins
<2006>
<2006>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
