Eric Bjorklund wrote: On Jul 14, 2006, at 7:45 AM, Kate Feng wrote:Do you mean the dummy read following the last write is needed for only vxWorks-mvme5500 ? Or is it needed for almost all the powrPC boards using VxWorks ? Does it apply to all the VME boards ? I believe it has to be the same register the write was targeted at. I had problems accessing indirect RAM (sequence RAM of EVG) with MVME5500 running vxWorks. I first thought it was a compiler optimization problem but the assembler listing was OK. I had to set up a VME bus analyzer to see what was happening on the bus. My test code looks following: STATUS ReadTest(MrfEvrStruct *pEvr, int ram) { volatile MrfEvrStruct *pEr = pEvr; int address; int control; int data[4]; /* Enable Ram for access */ control = pEr->Control & ~(EVR_C_VMERS | EVR_C_RSTS | EVR_C_HRTBT | EVR_C_IRQFL | EVR_C_LTS | EVR_C_NFRAM | EVR_C_RSADR | EVR_C_RSFIFO | EVR_C_FF | EVR_C_FNE | EVR_C_RSDLIRQ | EVR_C_RXVIO); if (ram == 2) control |= EVR_C_VMERS; pEr->Control = control; for (address = 0; address < 4; address++) { pEr->RamAddr = address; data[address] = pEr->RamData; } } In this code pEr->RamAddr and pEr->RamData are two consecutive two byte words in VME A16 memory space and the contents of pEr->RamData depend on the contents of pEr->RamAddr. And this is what I see on the bus, which is really not what I wanted: Read from pEr->Control Read from pEr->RamData Read from pEr->RamData Write to pEr->Control Read from pEr->RamData Write to pEr->RamAddr Read from pEr->RamData Write to pEr->RamAddr Write to pEr->RamAddr Write to pEr->RamAddr The only solution I found was to read back the address every time before reading the data. Regards, Jukka
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
