Ditto, writes are posted, reads are coupled. There are two posted
fifos, one in the local to PCI bridge and one in the PCI to VME bridge.
The only to get coupled behavior is to do a read. Cache flushes and
syncs don't go near where the problem is.
> -----Original Message-----
> From: Andrew Johnson [mailto:anj@aps.anl.gov]
> Sent: Thursday, July 13, 2006 12:45 PM
> To: Rees, NP (Nick)
> Cc: tech-talk@aps.anl.gov
> Subject: Re: Dev lib off-board register access
> Rees, NP (Nick) wrote:
> > This is really a follow-up to the 2002 thread on PowerPC caching:
> > http://www.aps.anl.gov/epics/tech-talk/2002/msg00417.php
> That thread ended up talking about write posting through the VME
bridge,
> I'm not sure whether it's the same thing you're talking about or not.
> > At Diamond we use the mvme5500. It seems that every vxWorks driver
we
> > have will fall over at some point unless we are careful with memory
> > caching. Very few EPICS drivers do this properly. However, on the
> > mvme5500 if we precede every read with a cacheInvalidate and follow
> > every write routine with a cacheFlush we don't seem to have any
> > problems.
> Caching should only be an issue if you have two bus masters accessing
> the same area of memory; i.e. if there is a DMA controller or a second
> CPU involved in the I/O operation. Not many EPICS drivers actually
use
> a DMA controller, so most drivers don't need to worry about cache
> coherency issues.
> There is an option in Marty Kraimer's Generic Transient Recorder
support
> to make use of some BSP-supplied DMA routines that I wrote for the
> Universe-2 and VMEchip2 bridges. My implementation of this VME DMA
> support *should* perform the necessary cache manipulation operations
at
> the appropriate time (the requirements are different on different
boards
> though; most boards can do bus snooping, but some do not and require
the
> driver to call cacheInvalidate() before reading and cacheFlush() after
> writing the shared area).
> Later, Rees, NP (Nick) wrote:
> > Peter Denison gave me the following link to the Linux kernel sources
> > which gives a reasonable description of sync, lwsync, eieio and wmb,
rmb
> > etc.
> > http://lxr.linux.no/source/include/asm-ppc64/system.h#L18
> > I assume that at the bottom of cacheFlush and cacheInvalidate is a
sync
> > instruction on the PPC, but I might be wrong. I certainly don't see
it.
> Not necessarily, since sync is an expensive instruction on the PowerPC
> which you would really rather not execute if you can avoid it. A
> cacheFlush() will perform other instructions that ensure the cache
area
> specified is definitely pushed out to memory before it returns, but
that
> doesn't necessarily need a sync.
> Note that all the VMEbus windows should be marked as Non-Cacheable and
> Guarded in your BSP's sysPhysMemDesc[] table.
> > The problem we have found with the 5500 is, I think, related to the
> > problem outlined in the 2002 tech-talk thread. The processor MMU may
> > know the VME memory isn't cached, but there is also a cache in the
VME
> > chip (why, I don't know) and that has to be forced as well.
> Ok, that's a different issue and not a cache; the Universe-2 VME
bridge
> chip has a write pipeline which enables a PCI bus write cycle to
> complete before the matching VMEbus cycle does. Cycles on VMEbus are
> generally much slower than on the PCIbus, and there's no reason to
hold
> up the processor just to wait for the cycle to complete, so the bridge
> chip has a write FIFO built into it that allows it to queue up a
series
> of write operations. This speeds up the processor operation quite a
> bit, at the expense of having to be a little more careful in the
> software (and a loss of synchronization with VME Bus errors, but
that's
> a slightly different topic).
> The bridge ensures that all pending VME write operations are performed
> before it will execute any subsequent VMEbus read, for which it has to
> delay the PCIbus cycle since it can't complete that without getting
the
> read data from the VME cycle anyway. This ensures that the I/O cycles
> are still performed in the same order that the CPU requested them, but
> the timing may be different.
> Usually the different timing that doesn't matter, but there is one
> circumstance where it does - clearing interrupt requests from VME
> boards. Here an Interrupt Service Routine needs to ensure that any
> write cycle going to a VME slave board that causes it to deassert an
IRQ
> line gets out to the board before we return from the ISR, otherwise
> nasty things happen. The way to guarantee this is to perform a dummy
> read from some register on the VME board at the end of the ISR, which
> pushes the VMEbus writes out and thus clears the IRQ condition.
> This should be sufficient to fix your problem; the cacheFlush and/or
> cacheInvalidate that you were calling were inserting a delay into the
> CPU instruction chain which was probably sufficient time for the VME
> write pipeline to flush itself naturally. Howere this is not
> guaranteed, so I suggest you fix these with the VME read instead.
> - Andrew
> Not everything that can be counted counts,
> and not everything that counts can be counted.
> -- Albert Einstein
- Re: Dev lib off-board register access Andrew Johnson
Re: Waveform record help Andrew Johnson
Accumulated beam current of 1mA, at an energy of 3GeV (First Light) at the Australian Synchrotron Richard Farnsworth
<2006>
<2006>
