Erik Johansson wrote:
If I bypass all EPICS db routines and fill the contents of a waveform
record by writing data directly to the BPTR address and then perform a
caget on the record, I get all zeros returned, regardless of the data
written. Why? What can I do so that caget returns the actual values in
the record? Note that I am doing this for debug/troubleshooting purposes
during system integration only.
You need to set the NORD field of the record as well, to indicate the
number of data items actually contained in the array - if you haven't
set it, it probably defaults to zero. Unfortunately the NORD field is
marked special(SPC_NOMOD) meaning that you can't set it from CA or using
dbpf, but I'll leave that as an exercise for you to work out...
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- Waveform record help Erik Johansson
RE: Dev lib off-board register access Thompson, David H.
<2006>
Thales Optem 30-17-70 Leicester, PJ (Pete)
<2006>
