1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: question about dbLoadTemplate()
To: Mark Rivers <[email protected]>, [email protected]
Date: Fri, 30 Jun 2006 15:46:24 -0400
Mark,
Thank you - it works.
Yesterday I was nearly and tried something like
file "top/db/motor.db" ...
where
top = "/ade/epics/iocTop/R3.14.7/SystemVerX/"
But it didn't work and I found another unliked way.
Now
file "$(TOP)/db/motor.db" ...
Thanks again, Andrei.
-----Original Message-----
Sent: Friday, June 30, 2006 1:46 PM
To: Liyu, Andrei; [email protected]
Hi Andrei,
dbLoadTemplate uses the environment variable substitution that EPICS
provide.  My .substitutions files look like this:
file "$(CARS)/CARSApp/Db/motor.db"
pattern
{P,       M,        DTYP,  C, S, DESC,                    EGU,   DIR,
VELO,   VBAS,   ACCL,  BDST,   BVEL,  BACC,   SREV,   UREV,  PREC,
DHLM,   DLLM}
{13LAB:, m1, "OMS VME58",  0, 0, "Tilt1",   degrees,   Pos,   .07,
0,     .2,     0,      1,    .2,   2000,    1.0,     4,     20,    -20}
{13LAB:, m2, "OMS VME58",  0, 1, "Tilt2",   degrees,   Pos,   .07,
{13LAB:, m3, "OMS VME58",  0, 2, "X",       mm,        Pos,   .07,
0,     .2,     0,      1,    .2,   2000,    1.0,     4,      8,     -8}
{13LAB:, m4, "OMS VME58",  0, 3, "Y",       mm,        Pos,   .07,
file "$(OPTICS)/opticsApp/Db/table.db"
pattern
{P,          Q,      T,  M0X,  M1X,    M2X,    M0Y,   M1Y,    M2Y,
M2Z,  GEOM}
{13LAB:, MON:T1, MON:t1, junk, junk,   junk,   m2,    m1,     m3,
junk,    SRI}
file "$(MOTOR)/motorApp/Db/sumDiff2D.db"
pattern
{P,      T,     SUM, DIFF,   M1DRV,    M1RBV,   M2DRV,   M2RBV,
M1STOP,   M1DONE,   M2STOP,   M2DONE,  PREC}
{13LAB:, KBV:,  pm1, pm2,    m7.VAL,   m7.RBV,  m8.VAL,  m8.RBV,
m7.STOP,  m7.DMOV,  m8.STOP,  m8.DMOV, 1}
file "$(SSCAN)/sscanApp/Db/scanParms.db"
{P=13LAB:,SCANREC=13LAB:scan1,Q=MON:T1X,POS=MON:t1.X,RDBK=MON:t1.XRB}
{P=13LAB:,SCANREC=13LAB:scan1,Q=MON:T1Y,POS=MON:t1.Y,RDBK=MON:t1.YRB}
{P=13LAB:,SCANREC=13LAB:scan1,Q=MON:T1Z,POS=MON:t1.Z,RDBK=MON:t1.ZRB}
{P=13LAB:,SCANREC=13LAB:scan1,Q=MON:T1AX,POS=MON:t1.AX,RDBK=MON:t1.AXRB}
{P=13LAB:,SCANREC=13LAB:scan1,Q=MON:T1AY,POS=MON:t1.AY,RDBK=MON:t1.AYRB}
{P=13LAB:,SCANREC=13LAB:scan1,Q=MON:T1AZ,POS=MON:t1.AZ,RDBK=MON:t1.AZRB}
So CARS, OPTICS, MOTOR and SSCAN are environment variables defined in
cdCommands (vxWorks) or envPaths (other systems).  These are maintained
by the EPICS build facility through configure/RELEASE.
Note that I am loading .db files directly from the source (App/Db)
directory, rather than installing into db/, but that is just a personal
preference.
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Friday, June 30, 2006 12:00 PM
> To: [email protected]
> Subject: question about dbLoadTemplate()
> Hi,
> Standard way to use dbLoadTemplate()is
> 1. ***st.cmd***
> cd $TOP
> dbLoadTemplate( "db/Test.substitutions")
> 2. Test.substitutions has links to templates files
> file db/Test1.template ...
> file db/Test2.template ...
> So Test.substitutions and templates (Test1.template and
> Test2.template)
> files should be in the same directory (in this example top/db/ )
> How can it be used if the files are in the different directories?
> I found a way in vxWorks.
> For example, Test.substitutions is in
> /ade/epics/iocCommon/"IOCName"/Data
> and Test.template is in
> /ade/epics/iocTop/R3.14.7/SystemX/R2-0/db. Then
> 1. st.cmd has
> SubstitutionPath=malloc( 100)
> sprintf SubstitutionPath, "/ade/epics/iocCommon/%s/Data",iocName
> nfsMount nfsServer,SubstitutionPath,"/SubPath"
> TemplatePath=malloc( 100)
> sprintf TemplatePath, "/ade/epics/iocTop/R3.14.7/SystemX/R2-0/db"
> nfsMount nfsServer, TemplatePath,"/TemPath"
> cd "/SubPath"
> dbLoadTemplate("Test.substitutions")
> 2. Test.substitutions file has
> file TemPath/Test1.template ...
> (!!! "file top/db/Test1.template ..." doesn't work)
> It works. But that is spaghetti's way and I suppose it will
> not work in
> Windows and Linux.
> So question:
> Has anyone done something similar (to have template and substitutions
> files in different directories)?
> Thanks, Andrei.
RE: question about dbLoadTemplate() Mark Rivers
Prev: Re: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Andrew Johnson
Next: Matlab interfaces Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: question about dbLoadTemplate() Mark Rivers
