Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: error while loading shared libraries
To: Stefan Bruins <brs@vonk-systems.nl>
Cc: TECHTALK Tech-Talk <tech-talk@aps.anl.gov>
Date: Fri, 30 Jun 2006 09:26:20 -0500
On Jun 30, 2006, at 7:02 AM, Ernest L. Williams Jr. wrote:
On Fri, 2006-06-30 at 10:21 +0200, Bruins, Stefan wrote:
When I try to put on the ASYN-4.3 driver on a linux computer a MAKE command
I get the error:
/opt/epicsbase3-14/bin/linux-x86/dbToRecordTypeH: error while loading shared
libraries: libdbStaticHost.so: cannot open shared object file: No such file
or directory
What am I doing wrong here?
Has your EPICS base been moved (renamed) or mangled after it was built?
Check that "/opt/epicsbase3-14/lib/linux-x86/libdbStaticHost.so" exists.
Then check that you have your LD_LIBRARY_PATH setup to point to the
location of your EPICS shared libraries
You shouldn't have to deal with LD_LIBRARY_PATH issues if you leave the libraries where they were built.
Also -- not that this has anything to do with the problem mentioned above, but ASYN-4.3 is getting to be a rather old release.
Eric Norum <norume@aps.anl.gov>
Advanced Photon Source
(630) 252-4793
error while loading shared libraries Bruins, Stefan
Re: error while loading shared libraries Ernest L. Williams Jr.
Prev: Re: error while loading shared libraries Ernest L. Williams Jr.
Next: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
