1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Sequencer embedded C code question
To: [email protected], "Eric Norum" <[email protected]>
Date: Thu, 29 Jun 2006 17:28:40 -0400
Eric,
Here is what the code looks like right now:
program snchygrometer
%%#include <ctype.h>
%%#include <stdlib.h>
%%#include <stdio.h>
 %%char rob[10] ;
 char *roba;
 assign roba to "rawdata" ;
 monitor roba ;
 float ch1 ;
 float ch2 ;
 float ch3 ;
 float ch4 ;
 float ch5 ;
 assign ch1 to "PV1";
 assign ch2 to "PV2";
 assign ch3 to "PV3";
 assign ch4 to "PV4";
 assign ch5 to "PV5";
  %%int v ;
  %%int z ;
  %%extern char *wa1 ;
  %%char *sign="+-" ;
when()
  rob=&roba; /*i dont know how to do this & wont work w/ roba as just rob*/
  v=rob[0];                /*Get first char from string*/
  wa1=strpbrk(rob, "+-");  /*Break string at +-,rest is wa1*/
  z=(float)wa1;            /*convert string to float z*/
ss ss1 {
  state state1 {
     when (    v==1) {
         ch1 = z; pvPut(ch1);
     } state state2
  state state2 {
     when (    v==2) {
         ch2 = z; pvPut(ch2);
     } state state3
  state state3 {
     when (    v==3) {
         ch3 = z; pvPut(ch3);
     } state state4
  state state4 {
     when (    v==4) {
         ch4 = z; pvPut(ch4);
     } state state5
  state state5 {
     when (    v==5) {
         ch5 = z; pvPut(ch5);
     } state state1
(This is the entire code). and here is the error we are getting:
make[3]: Entering directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I..
-I../../../include/os/Linux -I../../../include
-I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include/os/Linux
-I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include/os/Linux
-I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include/os/Linux
sncProgram.c
../sncExample.stt:35: warning: return type defaults to `int'
../sncExample.stt: In function `when':
../sncExample.stt:36: `roba' undeclared (first use in this function)
../sncExample.stt:36: (Each undeclared identifier is reported only once
../sncExample.stt:36: for each function it appears in.)
../sncExample.stt:39: pointer value used where a floating point value
was expected
make[3]: *** [sncProgram.o] Error 1
make[3]: Leaving directory
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp'
make: *** [hygrometerApp.install] Error 2
What we are wondering is, why does it think rob is defaulting to int,
when we are setting it as char??  Obviously, there is something wrong
with array vs pointer (this is what I have been telling to my
students), but this seems to compile without any issues outside of
EPICS (well, the original ones we started out did, anyway).
On 6/29/06, Eric Norum <[email protected]> wrote:
I'm not sure what you have changed, but the code you posted originally seems to be mixing up the notion of "array of characters" and "pointer to character". See my comment below:
  %%char rob[10] ;
  char *roba;
  monitor roba ;
  float ch1 ;
  float ch2 ;
  float ch3 ;
  float ch4 ;
  float ch5 ;
  int v ;
  float z ;
  %%char *sign="+-" ;
  rob=&roba                 <<<<<<<<<<<<< EVEN WITH A SEMICOLON AT THE  END
THIS LINE MAKES NO SENSE.
Perhaps you could mail me your latest code??
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: Sequencer embedded C code question Pete Jemian
Re: Sequencer embedded C code question Eric Norum
Re: Sequencer embedded C code question Jiro Fujita
RE: Sequencer embedded C code question Laznovsky, Michael
Prev: Re: Sequencer embedded C code question Jiro Fujita
Next: Re: Sequencer embedded C code question Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Sequencer embedded C code question Eric Norum
