1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Sequencer embedded C code question
To: [email protected], "Tim Mooney" <[email protected]>
Date: Thu, 29 Jun 2006 17:13:44 -0400
Thanks, Tim.
I will also look into this as well.  I think we may actually be using
some part of this on the production machines (I know we use some part
of SynApps, so may be I should have on the test machine).
On 6/29/06, Tim Mooney <[email protected]> wrote:
I'm not sure if this will be any less trouble than the solution you're
already pursuing, because it requires a record that is not part of EPICS base.
But if you happen to have the sCalcout record available, you can do this with
an sCalcout and a dfanout.  Here's what the database would look like:
scalc.INAA = <link to input string>   # string from serial device
scalc.CALC = "int(aa)"                # get channel number
scalc.DOPT = "Use OCAL"               # evaluate '.OCAL' expression
scalc.OCAL = "dbl(aa[1,-1])"          # get value (skip past channel number)
scalc.OUT  = "dfanout.VAL PP"         # write value to dfanout
dfanout.SELM = "Specified"            # only write to link specified via SELL
dfanout.SELL = "scalc.VAL NPP"        # scalc calculated link to use
dfanout.OUTB = <link to channel 1 PV> # if scalc.VAL==1, write to <channel 1 PV>
dfanout.OUTC = <link to channel 2 PV> # ...and so on
dfanout.OUTD = <link to channel 3 PV>
dfanout.OUTE = <link to channel 4 PV>
dfanout.OUTF = <link to channel 5 PV>
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
Sequencer embedded C code question Jiro Fujita
Re: Sequencer embedded C code question Tim Mooney
Prev: Re: Sequencer embedded C code question Maren Purves
Next: Re: Sequencer embedded C code question Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Sequencer embedded C code question Dirk Zimoch
