Hello, This is probably really an elementary question, but we have been trying to interface an RS-232 device to EPICS soft IOC on Linux. We are using EPICS 3.14.8.2 with Asyn 4.6 (devGpib) via serial port. The response from the device looks like this: 1+32.23 2-50.01 3+23.98 ... ... It has five channels, reads one value a second, contiunally sending the message through the serial port (that seems to be a typical thing here at STAR/BNL). We need to have the data sorted into five different PVs, based upon the channel names. In the end, the example above should look like this: channel 1: 32.23 channel 2: -50.01 channel 3: 23.98 Because we need the channel number and the + or - sign in the raw data, I am taking the data into the IOC as string, having the sequencer split the channel number, based upon that, we are trying to put the value into the database. Well, so far, we have not been successful in writing the sequencer code. To the best of my knowledge, the sequencer cannot manipulat text strings, we are escaping all of that to C within the sequencer code, but we are getting a number of errors upon make. Here is the error message we are getting: make[3]: Entering directory `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -g -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include/os/Linux -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include/os/Linux -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include -I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include/os/Linux -I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include sncProgram.c ../sncExample.stt:34: warning: type defaults to `int' in declaration of `rob' ../sncExample.stt:34: conflicting types for `rob' ../sncExample.stt:9: previous declaration of `rob' ../sncExample.stt:35: `roba' undeclared here (not in a function) ../sncExample.stt:35: syntax error before "v" ../sncExample.stt:36: warning: type defaults to `int' in declaration of `wa1' ../sncExample.stt:36: conflicting types for `wa1' ../sncExample.stt:29: previous declaration of `wa1' ../sncExample.stt:36: braced-group within expression allowed only inside a function ../sncExample.stt:36: syntax error before string constant ../sncExample.stt:37: warning: type defaults to `int' in declaration of `z' ../sncExample.stt:37: initializer element is not constant ../sncExample.stt:37: warning: data definition has no type or storage class make[3]: *** [sncProgram.o] Error 1 make[3]: Leaving directory `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86' and here is the code: program snchygrometer %%#include <ctype.h> %%#include <stdlib.h> %%#include <stdio.h> %%char rob[10] ; char *roba; assign roba to "rawdata" ; monitor roba ; float ch1 ; float ch2 ; float ch3 ; float ch4 ; float ch5 ; assign ch1 to "PV1"; assign ch2 to "PV2"; assign ch3 to "PV3"; assign ch4 to "PV4"; assign ch5 to "PV5"; int v ; float z ; %%extern char *wa1 ; %%char *sign="+-" ; %{ rob=&roba v=rob[0]; /*Get first char from string*/ wa1=strpbrk(rob, "+-"); /*Break string at +-,rest is wa1*/ z=(float)wa1; /*convert string to float z*/ }% ss ss1 { state state1 { when ( v==1) { ch1 = z; pvPut(ch1); } state state2 } state state2 { when ( v==2) { ch2 = z; pvPut(ch2); } state state3 } state state3 { when ( v==3) { ch3 = z; pvPut(ch3); } state state4 } state state4 { when ( v==4) { ch4 = z; pvPut(ch4); } state state5 } state state5 { when ( v==5) { ch5 = z; pvPut(ch5); } state state1 } }
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
