1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: multiple definition error when compiling base 3.14
To: "tech-talk " <[email protected]>
Date: Thu, 29 Jun 2006 20:41:30 +0800 (CST)
hi,all
when I compiled base3.14.8.2 on Monta Vista Linux, gcc version is 3.3. I met the following error message:
ipx422
Installing library ../../../lib/linux-ixp422/libCom.a
/usr/local/mxscaleb/bin/mxscaleb-ranlib ../../../lib/linux-ixp422/libCom.a
/usr/local/mxscaleb/bin/mxscaleb-g++  -o libCom.so -shared -fPIC         -L/usr/local/mxscaleb/mxscaleb/lib -W\
l,-rpath-link,../../../lib/linux-ixp422         bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calc\
Perform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog\
.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocLog.o logClient.o macCore.o macEnv\
.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o tru\
ncateFile.o ipAddrToAsciiAsynchronous.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.\
o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osd\
FindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o \
osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o taskwd.o ep\
icsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o         \
-lm -lrt -lgcc
epicsTime.o(.bss+0x0): multiple definition of `__gnu_cxx::_Atomic_add_mutex'
ipAddrToAsciiAsynchronous.o(.bss+0x0): first defined here
osdMessageQueue.o(.bss+0x0): multiple definition of `__gnu_cxx::_Atomic_add_mutex'
epicsTimer.o(.bss+0x0): multiple definition of `__gnu_cxx::_Atomic_add_mutex'
timer.o(.bss+0x0): multiple definition of `__gnu_cxx::_Atomic_add_mutex'
collect2: ld returned 1 exit status
make[3]: *** [libCom.so] Error 1
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-ixp422'
make[2]: *** [linux-ixp422] Error 2
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom'
make[1]: *** [libCom.linux-ixp422] Error 2
make[1]: Leaving directory `/usr/local/epics/base-3.14.8.2/src'
make: *** [src.linux-ixp422] Error 2
  I guess maybe the reason is because I use the wrong switch of gcc. Can anyone give me some suggestions? thanks a lot in advance.
你 不 想 试 试 今 夏 最 “酷” 的 邮 箱 吗 ?
蕴 涵 中 华 传 统 文 化 于 世 界 一 流 科 技 之 中,创 新 Ajax 技 术,126 “D 计 划”火 热 体 验 中 !
Prev: CapFast Linux version Dr. Chong Lee
Next: Sequencer embedded C code question Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
