Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Gateway Crashes
To: Russ Berg <Russ.Berg@lightsource.ca>
Cc: Steven Banks <steven.banks@synchrotron.vic.gov.au>, tech-talk@aps.anl.gov
Date: Tue, 27 Jun 2006 13:29:50 +0200
I think, the EPICS_CA_MAX_ARRAY_BYTES problem is something else. In my experience, the gateway just becomes braindead, uses 100% CPU, stops any communication and does not even write an error message if you try to read a waveform which is larger than EPICS_CA_MAX_ARRAY_BYTES. In my opinion, the EPICS_CA_MAX_ARRAY_BYTES variable is a bad idea anyway, because for a generic application like the gateway, you can't know the maximum data size in advance. There should be something more flexible in the underlying CA code. (Even though that could lead to memory fragmentation.)
Dirk
Russ Berg wrote:
Steven,
I am not familiar with the gateway code and this is likely not your problem but it may give you some idea's, I have been able to crash our gateway when the EPICS_CA_MAX_ARRAY_BYTES environ var is not set and you try to pull a waveform or analog array back through the gateway, I think the default is 16k bytes, this needs to be set on the IOC and wherever your GUI is. Again I don't recall any messages about pthread_create calving, but setting the max bytes to a value large enough made the gateway happy.
When you dial back the number of connections the problem goes away? if so, at what number of connections does it die?
-Russ
From: Steven Banks [mailto:steven.banks@synchrotron.vic.gov.au]
Sent: Monday, June 26, 2006 12:57 AM
To: tech-talk@aps.anl.gov
Subject: Gateway Crashes
We are having severe problems with the EPICS gateway, and I'm hoping that someone can help us resolve them.
The problem is that the gateway is continually crashing whenever we open up a GUI display with requires connection to multiple IOCs. These are Libera BPM boxes, and we have 98 of them. We have a status display which shows the status of 33 of these at once. As we scroll from one display to the other, the gateway invariably crashes.
(This is a gateway between our office network and our accelerator network, and is used for monitoring the status of the machine from our desktops.)
The gateway log provides the following information:
Jun 26 16:01:02 PV Gateway Version 2.0.0.0 [Jun 14 2006 15:10:22]
EPICS 3.14.6 PID=8840 ServerPID=8839
EPICS_CA_ADDR_LIST=BROADCAST-ACC
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CA_MAX_ARRAY_BYTES=Not specified
EPICS_CAS_INTF_ADDR_LIST=CR01GW01-OFFICE
EPICS_CAS_SERVER_PORT=Not specified
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Running as user ics on host CR01GW01
Statistics PV prefix is CR01GW01
pthread_create error Cannot allocate memory
Jun 26 16:36:12 !!! Errlog message received (message is above)
fatal error: epicsThreadCreate
Has anyone else seen the memory problems that we are experiencing? Is this an indication that we are trying to connect to too many PVs at once? Will purchasing more memory for the gateway perhaps alleviate the problem. It currently has 512MB but we are planning to upgrade it to 1 GB.
Dr. Steven M. Banks – Control Systems Engineer
Australian Synchrotron Project
Major Projects Victoria
800 Blackburn Road
CLAYTON VIC 3168
tel: +613 8540 4103
fax: +613 8540 4200
http://www.synchrotron.vic.gov.au <http://www.synchrotron.vic.gov.au/>
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
Re: Gateway Crashes Steven Banks
RE: Gateway Crashes Russ Berg
Prev: save/restore Ian A Smith
Next: Re: Gateway Crashes Steven Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: RE: Gateway Crashes Russ Berg
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
