1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: About building base3.14.8.2 on winxp
To: "'Gan Quan'" <[email protected]>, <[email protected]>
Date: Mon, 26 Jun 2006 09:03:43 +0900
Are you using the Visual C++ 2005?
There is a problem to compile R3.14.8.2 using VC++ 2005.
You can get the answer from the KnownProblems Link:
http://www.aps.anl.gov/epics/base/R3-14/8-docs/KnownProblems.html
There is a hint about "Install binaries rule breaks build on non-cygwin
WIN32".
Guobao Shen
J-PARC Control Group
> -----Original Message-----
> From: Gan Quan [mailto:[email protected]]
> Sent: Sunday, June 25, 2006 4:48 PM
> To: [email protected]
> Subject: About building base3.14.8.2 on winxp
> Hi, everyone,
> I'm installing base3.14.8.2 on winxp. there are some error
> like these:
> who knows the reason? Thanks!
> forceBadAllocException.cpp
> rc -l 0x409 -I. -I.. -I../../../src/libCom/bucketLib -
> I../../../src/libCom/ring
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -
> ppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -
> I../../../s
> rc/libCom/ellLib -I../../../src/libCom/env
> -I../../../src/libCom/error -
> I../../.
> ./src/libCom/fdmgr -I../../../src/libCom/freeList -
> I../../../src/libCom/gpHash -
> I../../../src/libCom/logClient -I../../../src/libCom/macLib -
> I../../../src/libCo
> m/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -
> I../../../src/lib
> Com/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -
> I../../../in
> clude        -fo Com.res ../Com.rc
> link /nologo /subsystem:windows /dll /LTCG /incremental:no
> /opt:ref /release
> /ve
> rsion:3.14    /implib:Com.lib /out:Com.dll       bucketLib.obj
> epicsRingPointer.
> obj epicsRingBytes.obj postfix.obj calcPerform.obj cvtFast.obj
> resourceLib.obj e
> picsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj envSubr.obj
> envData.obj
>  errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj fdManager.obj
> freeListLib.obj
> gpHashLib.obj iocLog.obj logClient.obj macCore.obj macEnv.obj
> macUtil.obj
> aToIPA
> ddr.obj adjustment.obj cantProceed.obj epicsConvert.obj epicsExit.obj
> epicsStdli
> b.obj epicsString.obj truncateFile.obj ipAddrToAsciiAsynchronous.obj
> epicsThread
> .obj epicsMutex.obj epicsEvent.obj epicsTime.obj
> epicsMessageQueue.obj
> osdSock.o
> bj osdSockAddrReuse.obj osiSock.obj systemCallIntMech.obj
> epicsSocketConvertErrn
> oToString.obj osdAssert.obj osdFindSymbol.obj osdInterrupt.obj
> osdPoolStatus.obj
>  osdSignal.obj osdEnv.obj epicsReadline.obj epicsTempFile.obj
> epicsStdio.obj
> osd
> Stdio.obj osdThread.obj osdMutex.obj osdEvent.obj osdTime.obj
> osdProcess.obj
> osd
> NetIntf.obj osdMessageQueue.obj taskwd.obj epicsTimer.obj timer.obj
> timerQueue.o
> bj timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj
> tsDefs.obj
>  epicsGetopt.obj setThreadName.obj forceBadAllocException.obj
> Com.res
> ws2_32
> .lib advapi32.lib user32.lib
> LINK : warning LNK4044: unrecognized option "LTCG"; ignored
>    Creating library Com.lib and object Com.exp
> LINK : warning LNK4049: locally defined symbol
> "_epicsScanDouble" imported
> "Installing binary ../../../bin/win32-x86/Com.dll"
> Usage:
>          [ -m mode ] file ... directory
>         -d             Create non-existing directories
>         -m mode        Set the mode for the installed file
> (0755 by default)
>         file           Name of file
>         directory      Destination directory
> Can't find file 'Com.dll*'
> make[3]: *** [../../../bin/win32-x86/Com.dll] Error 2
> make[3]: Leaving directory
> `D:/Epics/base-3.14.8.2/src/libCom/O.win32-x86'
> make[2]: *** [install.win32-x86] Error 2
> make[2]: Leaving directory `D:/Epics/base-3.14.8.2/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `D:/Epics/base-3.14.8.2/src'
> make: *** [src.install] Error 2
> Accelerator Physics Group,
> Accelerator Research Center
> Institute of High Energy Physics (IHEP)
> P.O. Box 918-10
> Beijing, 100039
> P.R. China
About building base3.14.8.2 on winxp Gan Quan
Prev: About building base3.14.8.2 on winxp Gan Quan
Next: Gateway Crashes Steven Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
